SOURCE: Washing Machine fills slowly how to change inlet valve
switch off power remove top switch off water and remove hose. remove inside pipe from valve - usually held by just a spring clip remove electrical terminals valve is just held with a couple of screws usually - remove these and valve will come away. put back in same order
SOURCE: How do you "undo" the aqua stop?
create an inverted trap in ther dishwasher drain line so the water cant back feed
SOURCE: Half way through a program then stops, leaving water in the bottom of the machine
Check the flood switch first. It will stop the dishwasher but you may hear a moter running.
SOURCE: G879 Miele dishwasher does not startup
I found the solution by phoning Miele. You just have to reset as follows: switch on with program 2 and 3 pushed in. Then push top solo twice. Switch off and on again. The Miele is ready to go.
