SOURCE: Solution for canon ir 2520 error code E000020
E020 0000
The path between the sub hopper and the developing
assembly is clogged with toner.
1.Check the rotation of hopper motor gear. (If rotating, false
detection by the sensor is doubted. Feed the toner to the
developing unit in service mode: CLEAR>ENGIN>TNRINST.)
2.Replace the Developing Assembly Toner Sensor (TS1).
3.Replace the Sub Hopper Toner Sensor (TS2).
4.Replace the DC Controller PCB (PCB4).
SERVICE MODE:
* 28 * or MENU and #
SOURCE: The copier is canon,image runner
e000020 is error with toner unit,
several possibility :
- The toner is empty
- The developer failsto be replenished with starter developer properly.
- Related developing unit
- Ahopper motor error is identified by the detail code of E020. However, it may be identified by E02x according to need.
SOURCE: solution to errorE000003 0f ir 2520
Press the additionel function button & press 2&8 buttons at once and again press additionel function .select COPIER and FUNCTION and CLEAR and ERROR andpress OK button.
