SOURCE: my little brother was messing
dear friend,
1) Log in to your google account on your pc, the same account you registered for your phone
2) After logging in look at the top right corner of your inbox/email page, it would say your google username. Like say if you name is John, and you have a google id thats registered to your galaxy s as ,[email protected]. Now this google id on the top right corner of the page would be displayed as[email protected]
3) Type in the google id, thats visible on the right hand top corner of your page (like[email protected]) into your galaxy s handset locked page, and type in the password.
TADA AND YOUR ON TO THE NEW SCREEN TELLING YOU TO PUT IN ANOTHER PATTERN.
or theres this one:
Take out the battery, the sim card, and the SD card leave the phone for 2 to 3 hours like that.. Put everything back in and boot up the phone.. This should work.
You could try this instead of waiting 3 hours, just remove battery and press power on switch for 20 seconds but this may not work.
or if you've tried everything, the only other way would be to take it to a Samsung mobile phone shop.
or do a factory reset:
THIS WILL ERASE ALL YOUR DATA THOUGH
Go into recovery mode - vol up & home & power. Once in the menu, select factory reset.It may take you a couple of attempts to get to the recovery mode but it does work, just keep trying.
enjoy & Cheers
SOURCE: samsung galaxy s mobile completely
You can do a complete reset if you want and have no other option(this will erase all your data). To do this follow these steps.
Scroll to wipe data/factory reset using the volume buttons. to select it press the home button
SOURCE: my daughter entered the wrong
For all android devices a google mail account is needed for purchasing apps etc. if he did not set this up and had set the pass code without the email specified the only way to get back into the phone would be to do a complete reset. Before you do this have you tried restarting the device and seeing if it gives you the ability to try to enter the code again, if not here is how to do a factory reset. As stated below this will delete everything on the sd card so i would advise you copy all the files from it onto your computer. the entire process should only take about 10 to 15 minutes depending on the phone sometimes less than this, good luck!
Performing a factory reset (hard reset)
If you're passing your phone on to someone else or your phone has a persistent problem that cannot be solved, you can do a factory reset (also called a hard reset). This returns your phone to the state it was in before the first time you turned it on.
Note: Factory reset will not remove the data and files that are in your phone's microSD card.
Factory reset is not a step to be taken lightly. It will permanently delete all your data and customized settings, and will also remove any applications you've downloaded and installed. Be sure to back up any data and files you want to keep before you do a factory reset.
Performing a factory reset using phone buttons
If you cannot turn on your phone or access the phone settings, you can still perform a factory reset by using the buttons on the phone.
SOURCE: Need to 'hard reset' my Samsung Galaxy Europa
I attempted the above in order to hard reset my Europa i5500. However, it didn't work, and instead just went back to the "enter address/password" screen. I've attempted to connect to Kies, but to no avail, Kies doesn't register that the product is plugged in. I can get the phone onto download mode and emergency download mode, however neither are helping me much. Any suggestions?
SOURCE: i forgot my google account on my samsung galaxy gt-s5360 that's why i cannot unlock it
i cannot open samsung galaxy y GT s5360. i forgot my google account and passward
