This is beyond skill level of most people. Depends on where you are but new electric heaters cost as little as $20. All 1500 watt heaters produce the same amount of heat.
Bench test. With heater tore apart, energized, a volt meter connected across the sensor will indicate a voltage when it opens. take note of aproximate temperature and compare with the sensor temp rated value.
It takes a bit of skill to trouble shoot, repair, and put it back together. Toss it out if in doubt.
