Health & Beauty Logo
Lorrie Stimac Posted on Jan 22, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have scaling and moisture behind my ears. What is it
ian mcfie
Level 2:
Habit-Forming:
  • Expert 147 Answers
  • Posted on Jan 22, 2019
ian mcfie
Expert
Level 2:
Habit-Forming:
Answers
147
Questions
Helped
51783
Points
470
Seborrheic dermatitis of the ears often complain mostly about the itching, which can occur on the ear or in the ear canal. They may also complain about the scaly crust that develops on the front of the ear or behind the crease of the ear. Lastly, they may actually have such thick crust that they think they have a lesion or growth and come in for me to check it to be certain that it is not a cancer. Like seborrheic dermatitis on the face and scalp, ear seborrheic dermatitis is treatable but not curable.
My Kohler 35RZ generator Auxiliary Faults on startup after a rain storm. It Otherwise starts right up and runs. .
That is the specific use of WD40. Spray it when it is warm and the kerosene will evaporate and leave the waxy protective coating behind.
Problem with bathroom scales Model 9700 firstly inaccurate weighing and now just shows 'Err'.
Yaaaa... I know what you mean. Please know (OFTEN) there is LOTS of moisture in the bathroom air so the insides of these scales and other items get contaminated and RUST!
Your scale has reached "EOL" or end of life.
I know of no scale that is RUST resistant? I am not saying none are made... just none I know of.
Hope this helps!
Anthony
(SAY "Thank You")
3helpful
Crane sports body fat scale instructions
I bought mine at aldi and instructions are downloadable online
Key is to search under medion who makes crane scales Use the Model number behind the MD on the back of the scale to search and I've found a lot of downloadable PDF files for medion crane body fat scales My toddler switched the lb to kg so I had to find instructions online to change it back
4helpful
I would like to change my ThermoScan from Celsius to Fahrenheit but I am not sure what buttons to push to achieve this
Changing the temperature scale from F to C: - - Turn on the thermometer - If the unit is already on, make sure it is not in the memory mode - Press the ?/MEM button and keep it pressed. Then press and release the activation button to switch over to the "change temperature scale" mode. - By pressing the activation button again, the opposite scale will be activated. Each further pressing of the activation button rotates the measuring scale
How do I change my Braun ear thermometer back to F from C
You did not provide a model number however the Instruction Manuals for the various Braun Thermometers can be found here:
http://braun.kaz.com/kaz/service/prodResult/
Not sure if this procedure is common to all but this may work otherwise find the manual specific to your model number.
This thermometer is shipped with the Celsius temperature scale activated. If you wish to switch to Fahrenheit ( °F), proceed as follows:
Turn on the thermometer. ( If it is already turned on, make sure it is not in memory mode.)
Press the /mem button and keep it pressed. Then press and release the activation button to switch over to the «change temperature scale» mode.
By pressing the activation button again, the Fahrenheit scale is activated, «°F» is displayed on the LCD. Each further pressing of the activation button toggles the scale between °C and °F.
Release the /mem button to return to the ready symbol . The temperature stored in memory will automatically be converted to the selected scale when displayed on the LCD.
Siemens Pure 501 RIC Serial No RW52119 The above unit is in the right ear and periodically does not produce any sound. The RIC cord has been replaced once and still the problem persists. Pushing...
It could be a receiver issue, the cord, it might be a faulty receiver or alternatively it could be plugged with wax or badly affected by moisture. Receiver issues are relatively common with Siemens, if you have cleaned out the tip and are confident it is not a moisture issue, the receiver has failed. it is an easy fix and your audi should be able to change it out on the spot.
Need to change the farenheit
Here is a link to the manual:
http://braun.kaz.com/files/IRT3020GB,%20F,%20E%20%28USA,%20CDN,%20MEX%29.pdf
Or just follow these steps:
• Turn on the thermometer.
(If it is already turned on, make sure it is not in memory mode.)
• Press the /mem button and keep it pressed. Then press and
• By pressing the activation button again, the Celsius scale is
activated, «°C» is displayed on the LCD. Each further pressing
• Release the /mem button to return to the ready symbol .
All temperatures stored in memory will automatically be converted
I have replaced the batteries in my Glass WW scales and within a week it has needed some more. I have now done this twice. Buying the batteries at different shops, just in case it was them. Now I am...
this is the problem with moisture. and the circut is broken. i think the repair is costliar then new one
1 suggesion is daily remove the battery after weighting. and put it back when you needed
Top Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Health and Beauty Expert? Answer questions, earn points and help others
