What error code is it displaying and what is the brand model number and serial number? All units are a little different....I want to provide accurate answers....Help me help you....
Waiting to hear from you,
Eric and Ann Campion
P.S. Please keep in mind we help pay our staff with earnings from parts sales. Help us keep this valuable service free and order your parts from us. Visit our website for additional help at http://www.affordableappliance.com or for Parts Order Only, Call 1-570-622-6441
When you start your machine is the water just go stop go stop, Just wait for the machine to display an error code on the wash progress lights and beeps constantly. It could be the Rotor Position Sensor, out of balance switch or lid magnetic reed switch. Your error code will determine this. Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on.
Red spin light = 1
2nd rinse light =2
1st rinse light =4
last wash light=8
4th wash light=16
3rd wash light=32
2nd wash light=64
1st wash light=128
"FL" flashes if any overfill condition occurs. This condition occurs when
excessive water in the tub causes the overfill switch to trip. The control
must realize that the trip was due to an overfill condition instead of a
suds lock condition in order for "FL" to be displayed.
With an overfill condition, the beeper repeats a warning every 10 seconds
with no time out. The pump is cycled in drain mode for 30 seconds on, 30
seconds off until the overfill switch resets or power is discontinued to
the unit. Press STOP/CANCEL to clear the display.
The FL error code means: Flood Condition: FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%#@$
There is a release cord/string that can be accessed from the front of the soap/softner dispenser.
Remove the trays in the dispenser and reach towards the front of the machine. Find the end of the nylon line. Grasp firmly and pull to your left if your are facing the maching. I had to pull a few time before the door opened because I couldn't get a good grip and I didn't know how hard to pull without breaking the string. It might help to push in on the door at the same time, to realease.
I have to say, I was really surprized to find the nylon line as I was looking for a way to remove the tray and try reaching to see if there was a latch release.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^$#@
