Question about Nokia Computers & Internet
Charging and opening problem in NOKIA TA-1053?
My mobile is going out of charge when I connect it on charger last time it doing work but this time it dose not work and do not show any thing what its working or not and when i connect it on charger it dose not do any thing when i connect it with laptop there back area doing vibration lightly any body help me to fix the problem plz
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 10 Answers
Lightly insert a toothpick into the charge port and gently scrape back and forth to clean the contacts. If the tip of the toothpick comes out dark colored, repeat the process a few times.
Posted on Jan 22, 2019
SOURCE:
jaffi
  • 8 Answers
SOURCE: NOKIA 6630 displays not charging when connect charger
hi dude,
>>> dont remove any thing from u r mobile, first confirm the problem where it is...
>>> first try to put the charge by using other charger... still u r getting same problem means change the charging unit
>>>good luck... thank u....
>>> dont forget to rating the solutions...
Posted on Feb 16, 2008
mohammed387
  • 1952 Answers
SOURCE: nokia 2300 charging problem
just adjust or change the pin in mob
Posted on Feb 23, 2009
MNfisherman
  • 11896 Answers
SOURCE: Will work with charger just wont charge battery!
replace the charger. It may have weak or broken internal wiring, loose connection end, or it is just fried out. You can use a multi-meter to test charger. If charger is good, than you may have bad capacitor inside psp
Posted on Jun 05, 2009
  • 19 Answers
SOURCE: nokia 1650 keypad is not working and not charging
yaou must change your charging plugins its small and easy to be broke. key pad may be only dirt just clean it using a toothbrush and 90 % alcohol to clean it
Posted on Aug 15, 2009
SOURCE: 2008 nktel(china) bad charger connected During charging.
NKTEL 2008 Bad Cantect Chager
Posted on Feb 04, 2010
I can leave it plugged in for 24 hours and not have a full charge. Is this the batteries or the on board charger
There are a few things to consider with this type of problem.
How old are the batteries. When did you last have them tested. Is the charger output ok on load (test with an amp clamp type meter). is the charger the correct one for these batteries, small output chargers take longer to charge big batteries. Are all connection tight on batteries and anything to do with the charging circuit. Plug and socket type connection do fail on poor connections. Check voltage on batteries when on charge and off charge to see if the charger voltage is getting through to the batteries.
Jun 15, 2015 | Pride New Mobility Victory XL 4 Wheel...
My RCA tablet is charged but it won't turn on.
If it wont turn on how do you know it is charged ?. Are you sure the charger is working ?. connect the charger does the tablet show it charging ?. Over time I have replaced many faulty chargers .
Dec 27, 2014 | Tablets & eReaders
MY NOKIA CELLPHONE DIDNT WORK PROPERLY
Hi:
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jan 03, 2013 | Nokia N76 Cellular Phone
My nokia n81 8gb do not has charge,but battery is new
First Option:
Second Option:
Oct 25, 2012 | Nokia N81 Smartphone
WENT YOU PUT THE MAINS IN THE NEEDLE ON THE PAD SAID IT FULY CHARGE BUT THERE IS KNOW POWER LIGTH AND THE DC AMPERES IS NOT WORKING. CAN YOU LET ME KNOW IF IT THE BATTERYS. ARE IF YOU THINK IT MAY-BE...
Hi, if the meter is not showing a charge , it could be a number of problems, firstly make sure the lead from the charger pot is connecting okay to the batteries, you will need to remove the whole footplate to expose this, now having done that and convinced yourself that's okay , are you sure the charger working okay ?,,,, the last thing being the batteries will not accept a charge...sadly...the needle in the meter could be stuck,, is the scooter running okay and giving the impression the batteries are fully charged ? regards gewiz please rate this...
Sep 01, 2011 | Pride Sonic 3 Wheel Portable Scooter
Dear sir i have a china mobile Nktel A800, my mobile not charger support. i charge my mobile and my mobile show message bad charger connected, plz slove my problem, my no. +917737119777
repair your mobile...
i knw your problem... any time it will saw u charger connected without charger..
problem is in the socket of mobile where u connect charger to phone
May 17, 2011 | HP StorageWorks (A8000A) 16-Port Fibre...
Am using sony ericssion mobile model no. is w760a AT&T, from last two day am connecting charger, but its charging asusally, after i disconnect charger is showing battery empty..
Ifthe sell phone battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Feb 24, 2011 | AT&T Cell Phones
Nokia 3110c Charger not supported
First Option:
Second Option:
Dec 29, 2010 | Nokia 3110 Cellular Phone
How do i fix my asus eeepc that won't charge
First of all you have to narrow down your problem but finding out where is the problem exactly is it your battery or your charger so what you have to do find a charger from friend or so if similar is well and good
but always check the polarity it shold be exactly the same .and volts also then try to charge it its gives you a charged battery so you are sure its the problem with the charger and in the other case if still dosent charge its your batery so need replacement of either of 2.
other things you can check is when you plug in the charger to the laptop dose the notification comes on the light of plug and shows a batery with the plug icon on your taskbar. if yes just you need to check if its giving you the correct volts.
and if your laptop is working when connected to power only that means you have problem with battery .try removing it out for some time so its complitly drained and then clean the connection pins andreinsert it well and check.
thanks if its helpfull please cast some votes.
Dec 14, 2010 | Computers & Internet
Please help my nokia 2626 charger not support problem
First Option:
Secend Option:
Jul 13, 2010 | Nokia 2626 Mobile Phone
Computers & Internet Logo
51 people viewed this question
Top Nokia Computers & Internet Experts
k24674
Marvin
Marvin
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
