SOURCE: Dishwasher problem - no water in the tub
hi.
The sensore key that control the door of dish washer may be show that the door is open & it doesent let that water come to machine . you should checke the key
SOURCE: WATER NOT DRAINING OUT OF DISHWASHER AND SEEMS TO GO
This happened to me. Go to your local Lowes, Home Depot, etc and get some disposal claner. Clean the garbage disposal and see if that helps
SOURCE: dishwasher hums as if it is starting to run but no
Sounds like the solenoid isn't working. Either that or the pressure switch is telling the solenoid that it has water, a regular problem in hardwater areas. This can be temporarily fixed by removing the pink plastic pipe which is connected to the solenoid and draining the water out of it. I'm not sure whether the problem is with the solenoid or the pressure switch but its a bit of an exercise to get at the pressure switch. Zanussi have a mod kit to replace the pressure switch (5027 14 95-00/9) which your machine might find beneficial. My wife fixed our problem by ordering a new machine! She hates me fixing anything.
SOURCE: Dishwasher leaves water on dishes
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
