Microwave Ovens Logo
S
Stephen Kessler Posted on Jan 22, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a GE PEB1590DM2BB microwave/convection. The front door panel is scratched and I want to replace it. Is it difficult to pop off the front panel? How is it done?
Stephen Matthews
Level 2:
Habit-Forming:
  • Expert 107 Answers
  • Posted on Jan 24, 2019
Stephen Matthews
Expert
Level 2:
Habit-Forming:
Answers
107
Questions
0
Helped
31375
Points
215
Its not worth it to replace the door on that microwave, total cost of the door looks like 198.00 , maybe you could call GE parts and see if they have any in stock, WB56X10758 - However I highly doubt it is worth it. You are better off going to the website www.geappliances.com and finding a similar countertop microwave and just replace it with a new one. Perhaps if you call GE parts you could haggle them down on the cost of the door, however the labor of replacing it in that microwave isn't really worth it.
5 Related Answers
Anonymous
  • 473 Answers
  • Posted on Oct 05, 2007
SOURCE: GE Microwave JVM3660SD001 Control Panel Removal Procedure
Remove the grill, should be screws on the top of the unit. There should be one screw behind the grill at the top of the control panel. Remove it and pop the control panel up to remove it. Make sure the mw is unplugged first. Then you can remove the board.
Anonymous
  • 5911 Answers
  • Posted on Feb 27, 2008
SOURCE: Need to replace GE Spacemaker XL1400 door
On most microwavre ovens all you have to do is open the door all the way and lift straight up at the hinges. The door comes right off the hinge pins. In some cases you may have to remove the top louver panel (right above the door). You should NOT have to unmount the oven to complete this. In fact...I would not recommend it.
Is this a simple matter of replacing a door handle? If you need to only replace the door handle, you just lift slightly on the INNER door plastic around the glass and you will be able to access the door handle screws. There are a series of small grooves in the panel that you can use a small screwdriver to gently pry. You should not have to remove the entire panel. Just open it enough directly behind the door handle. Be careful when prying on the plastic. It can break if you're not careful. I hope this helps you.
freetek
Steve Allison
  • 5569 Answers
  • Posted on Jun 03, 2008
SOURCE: Burnt bulb in GE JE1590sc001 convection microwave
You can locate it by looking inside the cavity for an area that is perforated.
If this area is not a panel that can be removed, replacing it may (often) require removing a few sheet metal screws along the rear edge of the unit; rarely is the housing held on with more than that.
With the screws removed, lift up on the rear edge and pull toward the back.
DO NOT LEAVE IT PLUGGED IN!
Also, because there are components that may keep a charge (capacitors) for hours, I would recommend letting it sit unplugged overnight before removing the housing.
The bulb may be either a cylindrical type such as many sewing machines use or a smaller version of a standard bulb.
Neither of which anyone ever has at home, of course.
Any of the large 'home improvement' stores should have these 'made in China' bulbs at an inflated price.
Anonymous
  • 140 Answers
  • Posted on Jan 26, 2009
SOURCE: Condensation marks on microwave door
For most microwaves the process is pretty straightforward. You can open the door and you will see the screws that hold the outerinside panel on to the glass. After you remove those screws you will see the screws that hold the ouside cover to the door in place. Once you get that far you will see what is holding the glass in place. Keep in mind to replace the gaskets around the glass right and anything you take off to get to the glass itself. If you are getting condensation from range top cooking then the seal around the glass may need to be replaced. You really cannot hurt anything by taking it apart, but it needs to be put back together exactly the way you take it apart. Good luck and hope this helped.
Anonymous
  • Posted on May 27, 2009
SOURCE: scratches on microwave door
We have an over the range GE microwave and my wife was cooking some pasta on the stove and used the vent fan on the microwave to dissipate the steam and when we were done eating she noticed that the steam from the pasta had gotten in between the glass on the microwave door, how can we get rid of this any ideas.
2answers
How do i replace the inside light in the microwave?
If you see no panel on the inside of the unit, you will have to remove the housing.
If it isn't high-mounted, this isn't difficult; there are 3-5 screws around the edge of the back panel that keep the metallic housing in place. Once these are removed, lift the rear flange of the housing and tilt it forward, then pull it back toward you to release the front lip.
As a precaution; unplug the oven overnight since there are components that can keep a nasty electrical charge for hours, maybe not life-threatening but highly unpleasant.
GE Profile PK916, Convc. elements stays on high
he is right in what he says the heating element is feed from the main control board
4helpful
2answers
The door handle on my GE Profile ADvantium 120 Microwave is broke
appliancepartspros.com. part number AP3187809 $56.40 plus shipping
1helpful
GE JVM1190WY 003 Microwave Convection sparks
The problem that you are having is that the magnetron inside the microwave is shorting out to ground and it will find the shortest path to reach whatever has metal in it. Replacing the magnetron will solve your problem altogether and you need not do anything else different and continue using your metal racks.
Door hard to open on GE Advantium
That's odd.
I think you're just going to have to examine it while opening and closing the door.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
That can help. Good luck.
Need to Replace Door Handle for KitchenAid Over Range Microwave Hood Combo KHMS147KSS
Check out this door frame diagram, specifically number 1805. It clips on to the door frame. Remove it using a dull table knife or something similar (be careful not to scratch or break anything). You will then have access to the bottom screw.
GE Monogram Convection oven ZET837SB1SS
I would suspect a couple of wires are crossed.
GE puts mini-manuals in their units, which have wiring diagrams, schematics, etc. Very handy.
It will be folded up in a small envelope, usually behind the control panel or hidden elsewhere. That should help you.
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
