SOURCE: fuel pump problems 2003 s10 chev 4.3 v6
Your ECU is what acctivates your fuel pump realy. Put the key on the run possition and pull the ecu fuse for a few seconds and reinstall it ans it should accivate your realy for 5 seconds, Good luck.
SOURCE: Why is there no power going to my fuel pump? I've
may be the fuel pump is the problem it may need to be replaced....hope this helps.....cheers
SOURCE: no power to fuel pump relay so fuel pump not
Sometimes when the security system is not working properly, it can go into anti theft mode and literally shut down fuel pumps, injectors, or starters.... Read up on it thru this link and see if this might be your problem. http://vatspasslockpasskeysecurityhelp.yolasite.com/
SOURCE: which fuse is for the fuel pump relay on a 02' grand am
the one in the fuse box under the hood marked fuel pump
FAN NOT WORKING
It
can be issue with faulty motor or its faulty fan control relay.
Bother
are to be inspected.
Test
volt at fan relay and fan motor.
For
more help, I suggest you to go through the troubleshooting links
mentioned below:-----
Click
the link below: ------
How to replace Cooling Fan on Acura Car models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-cooling-fan-on-acura-car.html
OBD Code P1490 low speed fan relay ckt open-short
http://schematicsdiagram.blogspot.com/2012/11/obd-code-p1490-low-speed-fan-relay-ckt.html
Engine cooling components working?
http://repairhelpcenter.blogspot.com/2011/11/engine-cooling-components-working.html
How does Vehicles Engine cooling system works?
http://repairhelpcenter.blogspot.com/2011/11/how-does-vehicles-engine-cooling-system.html
Hyundai Sonata cooling fan not working
http://schematicsdiagram.blogspot.in/2012/02/hyundai-sonata-cooling-fan-not-working.html
Fuel pump relay and cooling fan relay troubleshooting on
1997 ford thunderbird?
http://repairhelpcenter.blogspot.com/2011/10/fuel-pump-relay-and-cooling-fan-relay.html
Fan belt routing diagram for 2004 Volkswagen Jetta?
http://carbeltrouting.blogspot.com/2011/12/fan-belt-routing-diagram-for-2004.html
Timing belt, drive belt, serpentine belt, accessory belt,
fan belt, engine belt routing diagrams for all types of car models?
http://carbeltrouting.blogspot.in/2012/02/timing-beltdrive-beltserpentine.html
A/C, heater, defroster fan, not working?
http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html
Blower fan not running on Isuzu trooper?
http://technoanswers.blogspot.in/2012/02/blower-fan-not-running-on-isuzu-trooper.html
How to replace blower motor fan assembly on 2000 GMC
Yukon?
http://repairhelpcenter.blogspot.com/2012/01/how-to-replace-blower-motor-fan.html
Heater AC or defroster fan not working on KIA?
http://technoanswers.blogspot.in/2012/02/heater-ac-or-defroster-fan-not-working.html
These
will help.
Thanks.
Press Ok, Accept or
replay
I have a solution for
this
Bruce
