Try this:
Switch off the appliance by pressing the O N/OFF button. Shut off
the water tap to eliminate the risk of flooding and remove the plug
from the electrical socket.
Make sure the water inlet filter has not become blocked by various impurities. (see "Care and maintenance" chapter)
SOURCE: Indesit DV620
check your manual it should tell you what this code means and wether you can deal with it yourself
SOURCE: Indesit DIF04 integrated dishwasher
Dishwashers normally are hot or cold feed.
My wife runs water at the sink to get it hot going in before turning on the dishwasher.
You can use either cold or hot water.
We have ours hooked up to the hot water side.
They work better hooked up to the hot water.
SOURCE: indesit dishwasher wont come on
this might be a little late but i ahve the same problem, an indesit engineer has been and there ia a metal bar the control wires rub against when opening/shutting the door. major design fault if you ask me. it tripped my entire kitchen and extention out.
SOURCE: Hi Indesit IDL700 Dishwasher. Stopped mid cycle by
The main processor was interuppted and so has hung up or is faulty. Remove the main plug and press on the control pad of the washing machine to drain off any residual voltage that is remaining on the main board and which seems to have hung up the processor.When the plug is plugged in and switch please hold down the start/stop button.
If there is no result after plugging in the machine then the main controller board is a suspect. You can remove the control board and check the connectors, check the main door switch , if possible clean the connectors/ contacts as a last chance.
flood float switch at the bottom of the dishwasher must be faulty.
