I have IP camera & DSL-2640T. I can watch in on MY local LAN pc's but not on internet..I get help from portforward.com but could't able to forward the port. Then i try to use dyndns.com, I made an Address their & put my local IP there which is 192.168.1.188..but still can't see over internet..Can anybody help me how to watch my IP camera on internet without buying any IP from ISP ? Is this possible? If yes then how..Help me please
Let me give you few suggestions and then you can take it from there.
firstly IP camera is just what its name says..it needs a fixed IP address it may be local as in your lan where it is working or a IP address from ISP.
Now when you connect it behind router... it is essentially a camera connected to LAN.
now the problem is DYNDNS.com will give access to your router since that is connected to dynamic IP addressing. However Ip camera is behind router and to access it you need to open proper protocol and port in router .consult your router manual for doing that.
with your current setup that is the only solution. however you can connect Ip camera directly to ISP line and then use dyndns as in case of router. though i dont know how feasible that will be for you.you have not mentioned IP camera model so cant help with specific details.
