Betacam sp pvw-2800p
SOURCE: sony uvw 1600 betacam sp does not power up
Check the power supply area for the fuses for one. Second, the power supplies in these units are switch mode supplies that require a jump start from a small cap. It is possible that the "starter cap" is defective. There are other reasons for this type of behavior as well. Keep us posted on what you find.
Dan
SOURCE: Sony PVW-2800 Beta SP Deck / Tape wont load - Error 20
Error 20 is "Cassette compartment motor lock" this is meaning the cassette loading mech is not accepting the tape It could be miss-aligned in it's position or one of the sensors is defective or the motor is bad
SOURCE: Betacam Sp Error Code
It seems mechanical problem and you need to apart unit.
I would advice you to get Maintenance Manual of BVW-75 before to open unit and get help from mechanical exploded section.
Below is picture of Maintenance Manual and part of mechanical exploded view...
It is high end broadcast model and needs care in maintenance.
Good Luck.
SOURCE: Beatcam SP error message
BVW-75 error 09 is "threading motor time out". Look for something obstructing the travel of the threading ring inside the deck (the ring which pulls the tape around the video head).
SOURCE: error code 02-694
The probem as told on another site (sorry, can't remember to give proper credit) is that the pinch roller is not making contact with the capstan. THis is exacly what happened to my 1800 after sitting for a long time with no use. THe solution was to manually excersize the lever going to the solenoid to unstick the mechanism. Then, voila, pinch roller pinches, tape moves, UVW1800 happy again.
