Washing Machines Logo
a
a s bennett Posted on Jan 22, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Did the reset and start icon is still flashing 24 hours later washer is a beko wmb91242 lc
Stan Naramore
Level 3:
Guru:
  • Master 531 Answers
  • Posted on Jan 22, 2019
Stan Naramore
Master
Level 3:
Guru:
Answers
531
Questions
Helped
208827
Points
2468
This has helped a lot of people with your Beko model https://www.youtube.com/watch?v=RFDur_lIzfg
3 Related Answers
A
Anonymous
  • Posted on Sep 26, 2007
SOURCE: Freezing on start up
I have had a aproblem with my digiwalker Mio, which also was freezing up. The only way to sort it is a HARD RESET. The problem in my case appears to be due to the start up program initiating GPS/Tom Tom at the same time. good luck
docjohn174
john gagnon
  • 943 Answers
  • Posted on Oct 01, 2008
SOURCE: Hi, I have a Beko
hi. thanks for the question . Check , the freezer fan motor, to see if its ok. check the coils at the back, and fan at the back . if all ok. check behind the freezer wall to see if all coils are frosting up .If all te coils are not frozen you have a faulty compressor .thanks the appliance doc
Anonymous
  • Posted on Jan 17, 2013
SOURCE: How to reset Beko wmb 91242 LC? Machine won't do
My washing machine beko WME7247W won't do anything it said C on it won't start change tem do anything can you help me
I bought a watch for my grandson. It had no instructions. It is from China MFG# FMDAW549. Are there directions available
Possibly these instructions:
http://forums.watchnet.com/index.php?t=tree&goto=110449&rid=0
DIGITAL WATCH USER INSTRUCTIONS May 27, 2006 - 05:59 PM On 5/26/2006 I bought from Walmart a $6.43 watch, on the back of which is written "AH 1175, 52, Battery CR2025, China Module, FMD, Base Metal Bezel, Stainless Steel Back, 100ft Water Resistant". It has no control buttons on top (where buttons may be accidentally pushed), the display is larger and more visible, and the color is dark, so I bought it even though I prefer models that have a fabric/velcro wrist-strap.
Four buttons on this watch are labelled: Light, Mode, Reset, and St/Sp. The instructions which I found inside its container refer to the Light button as A, the Mode button as B, the Reset button as C, and the Start/Stop button as D, but otherwise do not pertain to the watch, so I determined the button's functions by trial and error, as follows:
TO SELECT THE DISPLAY MODE
Push the Mode Button in order to select one of the following four display modes in the following order: Normal Time, Stop Watch, Alarm Reset, Time Reset.
In the Normal Time Mode, the Day of Week, the Hour, Minute and Second are displayed (none flash). If the Alarm and Hourly Chime icons are not displayed, the Alarm and Hourly Chime are turned off.
TO DISPLAY DAY OF WEEK, HOUR, MINUTE, SECOND AND WHETHER THE ALARM AND HOURLY CHIMES ARE ON:
Push the Mode button until no icon is flashing. The Alarm and Hourly Chimes are off if no Alarm or Chime icon is displayed beside the Second display.
TO DISPLAY THE DAY, MONTH AND DAY OF WEEK AND WHETHER THE ALARM AND HOURLY CHIMES ARE ON:
In Normal Time Mode, push the Start/Stop button. The Alarm and Hourly Chimes are off if no Alarm or Chime icon is displayed.
TO DISPLAY THE ALARM TIME
In Normal Time Mode, push the Reset button. The P or A beside the Alarm Time indicates PM or AM time. The P or A below the Alarm Time indicates a 12 hour clock; an H indicates a 24 hour clock.
TO STOP/START THE ALARM AND HOURLY CHIMES
In Normal Time Mode, hold the Start/Stop button down and push the Reset button (the Date and Day of Week will be displayed) to turn the preset Alarm and Hourly Chimes on, or off (to save the battery). To test the alarm, hold the Reset button down. The alarm and chimes are off when the alarm and chimes icons are not displayed.
TO STOP THE HOURLY CHIME
In Normal Time Mode, hold down the Reset button (the Alarm Time will be displayed) and push the Mode button until the Day of Week display is no longer highlighted; otherwise the hourly chime drains the battery.
TO SET THE TIME
To Fast/Forward until the correct number is displayed, hold the Start/Stop button down.
To set the Month of the Year, select the Time Reset Mode and push the Reset button until the Month of the Year number flashes; push the Start/Stop button until the correct Month of the Year is displayed and push the Reset Button.
To set the Day of Month, select the Time Reset Mode and push the Reset button until the Day of Month number flashes; push the Start/Stop button until the correct Day of Month is displayed and push the Reset Button.
To set the Day of Week, select the Time Reset Mode and push the Reset button until the Day of Week display flashes; push the Start/Stop button to until the correct Day of Week is displayed and push the Reset Button.
To set the Hour, select the Time Reset Mode and push the Reset button until the Hour number flashes; push the Start/Stop button until the correct Hour is displayed and push the Reset Button. For a 24 hour clock, push the reset button until an H is displayed. For a 12 hour clock, push the reset button until an A or P is displayed.
To set the Second, select the Time Reset Mode and push the Reset button until the Second number flashes. The Second number resets to Zero everytime the Start/Stop button is pushed. If the Start/Stop button is pushed as soon as the Second hand on your computer and watch are the same, the watch will be accurate to one second (to set your computer time to the second, log on to the Internet, right click on your PC's time display, select ADJUST DATE/TIME, INTERNET TIME, UPDATE NOW). The setting of the Second number will not be affected by setting the Minute number afterwards.
After the Second number is set, set the Minute number by selecting the Time Reset Mode and pushing the Reset button until the Minute number flashes; push the Start/Stop button until the correct Minute is displayed and push the Reset Button.
TO SET THE ALARM TIME AND TURN ON THE ALARM
Choose the Alarm Reset Mode. The alarm is turned on everytime the Alarm time is reset.
To select the Hour, push the Start/Stop button while the Hour is flashing and until the correct Hour is displayed, then push the Reset button (the Alarm and Hourly Chime icons will appear).
To select the Minute, push the Start/Stop button while the Minute is flashing and until the correct Minute is displayed, then push the Reset button.
Push the Mode button after the correct Alarm Time has been selected. The Alarm and Hourly Chime icons will be displayed beside the Second numbers.
The P icon indicates PM. The A icon indicates AM. The H icon indicates a 24 hour clock.
TO USE THE STOP WATCH
Choose the Stop Watch Mode. Push the Start/Stop button to begin the lap time. To pause the Stop Watch push the Start/Stop button to stop it and push it again to continue. To reset the Stop Watch to zero, stop the lap time by pushing the Start/Stop button, then push the Reset button (otherwise the Stop Watch will continue counting after other Modes are selected).
Apr 20, 2018 • Watches
4helpful
2answers
I have a beko washing machinethe start button keeps flashing during a cycle and it wont go on to the next cycle
Make sure that the inlet flow is good, remove the inlet valve to check. Also check the door switch and then the connections of the program controller unit. If there is loose connections it can cause errors and halt the program. Also it can be related to the program controller unit if after resetting the above there is no change .
Hello, I have a beko wm5100w and it seems to be stuck trying to pump out water. I have cleared the filter and pipes, but now I need to reset the machine. I have done the "switch off, turn to 90...
It could be a faulty thermistor (showing high temperature)
or water sensor fault that is causing the pump to run.
Just try and unplug it for 3-4 hours, and see if it resets itself,
if not replace sensors, and if that does not work, replace the main board.
Here is the manual:
http://laundry.manualsonline.com/manuals/mfg/beko/wm5100_1.html?p=21
This is the actual reset/diagnostic mode
https://www.youtube.com/watch?v=8C4J3leArY0
https://www.how-to-repair.com/help/beko-wm5100w-wm5100s-test-mode-and-error-codes/
1helpful
How do you change the time setting to 24 hours?
  • Press the "MODE" button---usually on the lower left side of the watch, but sometimes on the right center side---to cycle through to the time display.
  • Step 2 Press and hold the "SET" button---usually on the right lower side of the watch---until the seconds flash.
  • Step 3 Press "MODE" repeatedly to cycle through the displays that flash: from hours to minutes to month to date and day. At the end of the cycle is the hour display option. Make this option flash.
  • Step 4 Press the "SPLIT/RESET" button below the face of the watch to change the hour display option to "24-hour display." This is the same as military time. If there is a "NEXT" button on the upper-right side of the watch, use this to advance to the 24-hour option instead of using the "SPLIT/RESET" button. You may need to press a "START/SPLIT" button instead a "SPLIT/RESET" button to cycle between 12- and 24-hour display. The "START/SPLIT" button could be located below the watch face or on the upper-right side of the watch, depending on the model.
  • Step 5 Press the "SET" button again. You are now done. All PM hours should be displaying hours between 12 and 23.
  • 0helpful
    I have a 2 week old Beko dishwasher and last night I noticed that the lights were all flashing, I switched off and opened the door and the bottom of the machine is full of water. Any ideas?
    Either there is a leak activating the error alert or there is some blockage from the drain hose to the food dispenser.
    Unplug the power cord for 24 hour to reset the disrupted logic back to the original stage to see it it help. If the manual shows the diagnostic mode, try to set to manually drain so a new cycle can be started to test.
    May 06, 2010 • Dishwashers
    3helpful
    Beko wma765s washer error code 1L and flashing 1200 spin light washer completed wash but when went to load up again refused to start and 1200 spi n light flashing as well as flashing 1L in time remaining...
    Main board fault.engineer says not worth fixing.sourced board and replaced myself cost me £50 but have seen it priced at £63 and £86 .got mine by phoning Beko spares. took 10 days tho.as not in stock
    1helpful
    Dishwashwer won't start and can't reset to restart
    Check the float. (dome shaped thing inside the washer) Mine was stuck but as soon as I lifted up on it and then reseated it I was able to return to normal. Almost too easy. Saved $!
    22helpful
    2answers
    Beko wma641w reset
    hi
    to reset these al you do is press and hold the start button for about 5 seconds then it should reset if not then you have a faulty pcb
    regards
    Top Washing Machines Experts
    john h
