Radio Communications Logo
Ronald Cox Posted on Jan 22, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Remote key pad for IC-7610, I press a button and just get a beep like no memory is loaded, but memories on screen work.
suman chakraborty
Level 2:
Novelist:
  • Expert 66 Answers
  • Posted on Feb 26, 2023
suman chakraborty
Expert
Level 2:
Novelist:
Answers
66
Questions
0
Helped
7783
Points
138
If you're hearing a beep when pressing a button on the remote keypad for your IC-7610, it's possible that the keypad is not programmed correctly or is not communicating with the radio properly. Here are a few troubleshooting steps you can try:
  1. Check the connection: Make sure the remote keypad is securely connected to the radio's remote jack using the supplied cable.
  2. Check the settings: Make sure the remote keypad settings on the radio are configured correctly. Press the MENU button on the radio, select "Set" and then "Remote Operation." Check that the "Remote Type" setting is set to "IC-7610" and that the "Remote Address" matches the keypad's address.
  3. Check the keypad programming: Make sure the buttons on the keypad are programmed with the correct commands. You can check this by pressing the MENU button on the radio, selecting "Set" and then "Function Keys." The functions assigned to each key should be displayed on the screen. If they are not, you can program them by pressing and holding the F key on the keypad and then pressing the button you want to assign a function to.
  4. Reset the radio and keypad: Try resetting the radio and keypad to their factory settings. You can do this by pressing and holding the POWER button on the radio until it turns off, and then pressing and holding the FUNC button and the ENT button on the keypad while turning the radio back on.
If none of these steps work, it's possible that there is a hardware issue with either the radio or the keypad. You may want to contact the manufacturer's customer support for further assistance.
5 Related Answers
NickBeamAA
Nicholas Burress
  • 53 Answers
  • Posted on Sep 07, 2007
SOURCE: can only receive calls and turn the phone on and off! cannot dial out, access my contacts, ect., keypad not working at all.
If you are comfortable taking part of the phone apart there is something you can try. Remove the two Torx screws right below the battery. Gently pull the plastic cover loose. There will be a cable that connects this portion of the phone to the keypad/LCD/etc. Clean the connector on this cable and the connector it was plugged into with 99.5% Isopropyl alcohol. Reseat the cable and the part of the phone you removed and replace the screws you removed. If this does not work the keypad flex on the phone is probably damaged and will need to be looked at by a repair center.
Patrick
  • 56 Answers
  • Posted on Feb 04, 2008
SOURCE: My calculator is working well but only one button isn't working
I KNOW exactly what is wrong i had the same problem. you put a program like mirage or another application o your program on your calculator. no kids don't want teachers to deleter their games so mirage has a memory blocker. go into mirage then hit alpha then go to like protection options and stuff and turn off memory block. GOOD LUCK
Anonymous
  • 5 Answers
  • Posted on Mar 19, 2008
SOURCE: Toshiba Tecra 8100 will not boot, even the toshiba boot screen not displayed
http://eu.computers.toshiba-europe.com/cgi-bin/ToshibaCSG/faq.jsp?z=234&service=EU&from=faq_selection&CFID=BIOS&FID=TRO0000000b07
Thats a link to info about bios updates on the tosh website. If you're not getting to the toshiba screen then POST has not completed which means that either there's a hardware problem or the bios is corupt. If you're sure the RAM is ok try flashing the Bios.
Problem is though, to make the bios update disc, you need a working computer.
and, err, It'll probably have to be a toshiba!
(sorry, not my fault!)
A
Anonymous
  • Posted on Sep 29, 2008
SOURCE: Half part is display
replace ic
Anonymous
  • 17 Answers
  • Posted on Feb 02, 2009
SOURCE: Programming an Icom IC R5 scanner
This is a problem with any scanner which has no keypad..
First set the squelch (gets rid of the hissing noise and allows the radio to scan)
to do this....
On the side are 2 buttons, the bottom one is monitor.
press and hold then look at the display,
turn the top dial until "AUTO" appears,
The squelch should now keep the radio quiet.
Now the tuning step..
You need to set this because if your radio was on 450.000 and you wanted to listen to 450.012.5 you would miss it if your radio was making 000.025 "steps". IE you would need 12.5 steps. This is the most common step used by ambulance etc in the UK, you will need to check local band plans.
Stick with 12.5 and you should get most stuff on VHF / UHF.
For airband 12.5 will get most stuff, but some is now changing to 8.33.
For HF (below) 136 Mhz I'd use 5
To set the step....
On the front there are 4 big buttons.
press [V/M.S.MW.SKIP] to select VFO mode,
then press [BAND.LOCK] to select the band you want to listen to,
then press [TS.SET] to enter the step
turn the dial to select your step (stick with 12.5 for now)
press [TS.SET] to exit back to VFO mode
To scan...
First set the scan type...
Press and hold the one that says [MODE.SCAN] for 2 seconds and look at the display,
turn the top dial until the screen reads ALL,
press [MODE.SCAN] again and the radio should start to scan with the 12.5 steps you set earlier.
If you want to change scan direction, just turn the top dial.
If you want to stop the scan, just press [MODE.SCAN].
When you hear something interesting, make a note of the frequency on the display.
To set memories (store frequencies).....
to get close to the frequency you made a note of, press [BAND.LOCK]
Then set the actual frequency with the top dial,
press and hold [V/M.S.MW.SKIP] for 2 seconds to select memory write mode (1 short and 1 long beep)
turn the top dial to select which channel you would like to overwrite. Start with 01.
press [V/M.S.MW.SKIP] for 2 seconds. ( 3 beeps )
Thats it!
Any more problems just post on here and either me or someone else will help.
M3ODQ
How to erase memory in Brother 8690 MFC - it keeps printing unwanted faxes which are stored in the memory! It is junk mail and 20 pages long and I want to cancel it. When I press "Stop" and pull the power...
Try to press and hold Job Cancel button until a message Job Cancel (All) appears. Press OK to confirm.
If not working, the next is what I found in user manual:
Remove paper from the printer to stop it printing. Turn it on, if not.
Set Remote Access Code, if not already, pressing Menu, 2, 5, 2. Enter three digits - 1, 2, 3 - for example and press OK.
Dial your fax number from a telephone or another fax machine using touch tone. When your machine answers, immediately enter your Remote Access Code (these 3 digits followed by *). If you hear one long beep, machine is saying that you still have faxes in memory. Then you hear two short beeps, that mean the machine waits your command. Use the dial pad to press 9 6 3.
If you hear one long beep, fax messages have been erased from the memory.
4helpful
Nokia 7610 phone memory formatting manualy
You can format your phone by two methods
first method:
1) press *#7370#
2)enter your security code(note:default code is 12345)
3)restart your phone
second method:
1)switch off your phone
2)press power button,press and hold *key,3key,green call button
Dec 07, 2010 • Nokia 7610
Nokia 7610 softwere problem what shell i do it is suddenly switchingoff
its due to virus attack, just format the phone memory. 1- make necessary backup of your phone memory to pc. 2- turn off your device 3- press *3 call button and switch on button together,when the display starts release all the keys and you are done
alternative method type *#7370# and enter security code.... while the mobile is on...
Dec 04, 2010 • Nokia 7610
2answers
My keyboard has problem, some keys didn't work well and some key didn't work at all. when turned on the PC it sound beep beep and it won't stop unless i touch some keys on the keyboard
Hello.
The most common reason for your problem is memory.
First, disconnect all cables Flip your notebook and look for the memory cover. Loosen the screw and remove the cover. Reseat (remove and reinsert) the memory (you may have 2 modules). Replace the cover. Power on your notebook to see if problem resolved.
If still a problem, follow above but leave one memory module (if 2 modules). Power on and test. If still a problem, remove the module and replace with the other.
Hopefully, this procedure will resolve your problem or determine if one memory module is bad.
1helpful
The navigation keys of nokia supernova 7610 are not working.. and its memory card has also locked up itself ... plz help.....
open your phone cashing than also 4 screws under LCD.pick key pad,use( - )screw or cutter eyes.clean keypad connector use pencils erraser (it safety).also open white plastic on key pad clean it up too. its often happen.Good luck.
3helpful
2answers
When i start my laptop nothing happens except i hear i beep.I press the power button again and i hear one beep.After about six times an xp page comes on that says windows did not load sucessfully.I go to...
Try starting windows in safe mode by tapping F8 repeatedly right after you press the power button - a black and white screen will appear asking if you want to start in safe mode - the arrow keys select the mode, press enter, let it load fully then use the start menu to shut down and restart normally. Windows is simply telling you it cannot load properly this restores a good configuration again for it to use. Regarding wiggling the power cord - possibly the plugin is either loose or broken inside and the joints that connect it may have to be resoldered, the case has to be taken apart for that. One beep usually means all is well on IBM, three beeps indicate a problem, not necessarily only memory. The bios (F1 or F2 usually) may contain an error log indicating exactly what the problem is and will be indicated by a number code - IBM has a list on their site of what the number codes mean. Occasionally the error code may display on the screen upper corner on start up if you wait for it to show after the beeps.
1helpful
Nokia 7610 not working
you need to format your phone but you may lose all your memory details. To format your phone hold the following keys{* button, green/call button, 3 button and the power off button}. Holding these keys will format your button.
Jul 05, 2009 • Nokia 7610
1helpful
I have a nokia 7610, some message is coming in outbox pls find the solution for it
JONYCHEMIST FORMAT PHONE MEMORY BY THIS WAY, To format nokia 7610 phone memory follow the steps: 1. Switch off ur mobile. 2. Press *,3,green buttons together 3. Now switch on ur mobile. Press these buttons till you notice a formatting screen on ur mobile Note : Make sure that mobile is fully charged & transfer all the important files, messages, contacts to memory card. bye dis is JONYCHEMIST
May 04, 2009 • Nokia 7610
2helpful
KEYPAD PROBLEMS
Dear Make is software if ur phone key are working on wrong function. if not ok then change the key pad ic (both)even not ok then its prob from CUP check might be possible that when u press the button with speed ur mobile goes on restart then its prob from CPU.
Mar 30, 2007 • Nokia 7610
Top Icom Radio Communications Experts
eradiostore
eradiostore
Jim
Level 1 Expert
Are you an Icom Radio Communication Expert? Answer questions, earn points and help others
