Tools & Hardware - Others Logo
d
dennis dripps Posted on Jan 22, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Senco scn65 fires 1st nail then fires double nails
Chris Walker
Level 3:
Top Expert:
  • Master 1,573 Answers
  • Posted on Mar 15, 2019
Chris Walker
Master
Level 3:
Top Expert:
Answers
1573
Questions
Helped
1244950
Points
21965
5 Related Answers
Anonymous
  • 2176 Answers
  • Posted on Jan 01, 2009
SOURCE: Senco SN4 misfiring intermittently
This is a discontinued tool by Senco but there are still parts available for it. It sound to me that the o rings and possibly the firing valve need to be replaced. I would recommend going to Senco.com and you will find a complete parts diagram in their discontinued tool section. They also have a toll free number if needed and you can talk to their air pro. I have rebuilt quite a few of these and they are not that hard just make sure to clean all the parts and use lube when replacing O rings.
bwbconstruct
  • 23 Answers
  • Posted on May 11, 2009
SOURCE: senco 600 framing nailer / double hitting(nailing)
double nailing is usually caused when you apply to much pressure on gun causing it to fire on the recoil lighten up just tap it on the surface to be nailed
Anonymous
  • Posted on Jun 21, 2009
SOURCE: How to unload nails from Senco FinishPro 35
when you pull the spring back like your going to load it .put your finger in the hole and push it .you'll see that the nails will be release.
louisgugino
  • Posted on Sep 02, 2009
SOURCE: Senco nail gun was working one minute and then died...
gun nails frist nail then does not set next nail
Anonymous
  • 142 Answers
  • Posted on Dec 31, 2009
SOURCE: Senco 601 nailer shoots 2 nails each time the trigger is pulled.
the 601 had a design flaw, in the nose, where the nails hit as the are being pushed forward, the peice was made out of a peice of metal that was too soft, it wore down and that is where you get the double nail problem.
Senco offered a trade in, this was years ago, for a limited time and gave us credit towards new guns, which we gladly did
Why does my SENCO SCN65 shoot 2 nails at a time
If the trigger is worn out it can cause the nail gun to double fire. If the gun is set to bump fire and it is double firing in this setting then replace the trigger valve. If the nailer is set to trigger fire, then leaky O rings on the trigger valve can cause this.
My Senco Coil nailer, shoots one nail then shoots double nails
If your Senco coil nailer is shooting one nail followed by double nails, it could be due to several reasons:
  1. Jammed Nail: The first nail may have gotten stuck or jammed in the coil, and when the driver blade pushes down, it forces two nails to come out. You can try removing the jammed nail and reloading the coil.
  2. Depth Adjustment: The depth adjustment on your nailer may be set too deep, causing the driver blade to push down too far and shoot two nails instead of one. Try adjusting the depth control to a shallower setting.
  3. Worn Parts: The driver blade or nose piece may be worn out, causing it to push down unevenly and shoot double nails. In this case, you may need to replace these parts.
  4. Air Pressure: The air pressure on your compressor may be too high, causing the nailer to shoot double nails. Check the air pressure gauge and adjust it accordingly.
If you are unsure about how to troubleshoot or fix the issue, it's always best to consult the user manual or contact the manufacturer for assistance.
Senco Pro 18 Brad Nailer is Double firing
It appears to be a known issue
FinishPro® 18Mg - Senco
https://www.senco.com > docs > manuals-and-parts-charts
PDF FinishPro® 18Mg. 18 Ga. Brad Nailer. NFD81UMG Revised Mar. 11, 2014 (Replaces ... Fire." B First, ? pull trigger, then. ? push safety element against work surface for operation each time ... ? Double Action et ? Restriction. Dans certaines ...
FAQs ' SENCO
https://www.senco.com > faqs
A Restrictive Trigger tool will reduce the possibility of double fire and may reduce the speed of operation compared to a Dual Action Trigger tool. Call Customer ...
SOLVED: Shooting two nails instead of one - Fixya
https://www.fixya.com > support > t3317376-shooting_...
Question about Senco FP18 FinishPro 18 - Gauge Brad Nailer, 5/8" - 2" ... I would double check the plunger to make sure its resetting after each fire. Helpful 0 ...
nailer double nailing - Fine Homebuilding
https://www.finehomebuilding.com > forum > nailer-do...
Oct. 25, 2003 - I have a brand new bostich framing nailer and it is constantly double nailing and getting jammed. ... consider the senco framer I recently saw packaged with an 18 gage stapler for only $199 at Lowes. ... You can make the best of nailers double fire. ... Podcast 331: PRO TALK With Cabinetmaker Ben Scott ...
1helpful
My Senco finish nail gun only shoots a nail every OTHER pull of the trigger. It's a model SFN30 and does this about 65% of the time. It's clean and has really had very little use.
Your driver is not returning fully.
Most often this is caused by:
1) A bent driver blade - pull the driver out and inspect it, make sure it is straight.
2) A broken seal o-ring on the bottom end of the cylinder (#66)
Senco SFN30 15 Ga Finish Nailer Parts
1helpful
Senco fram pro 602 nail gun firers but no nail just a hole from firing pin
First, check that you are using the proper nails. The FP602 needs Full Round Head nails with plastic collation. If you are using Clipped Head nails with the paper tape collation the angle of the nails not let the driver catch the next nail and drive it into your work.
If you have the correct nails, check the magazine to make sure the nails are feeding all the way up to the driver. If there is anything blocking the way or if the spring on the feeder isn't taught enough to pull the clip all the way up the driver won't be able to catch the next nail and drive it in.
My Senco SFN1 finish nailer will not shoot a nail. When the trigger is pulled air comes out but no nail is shot. Thanks,Steve L
Not sure about Senco but most have latch you can open to expose firing mechanism. Nail sometimes gets jammed and will not allow driver to fire or if not nail push driver ****** all the way back into gun then see if gun will fire.
1helpful
i would double check the plunger to make sure its resetting after each fire.
Senco finish nailer not firing nails
firing pin called the driver is probably broken or needs new seals max air pressure 125 psi senco sells repair kits
1helpful
3answers
Senco 600 framing nailer / double hitting(nailing)
Top Senco Tools & Hardware - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Senco Tool and Hardware - Other Expert? Answer questions, earn points and help others
