I am pretty sure that is a very old microwave...for example it was original equipment on a 2005 Recreational Vehicle.
I am assuming you have been using that exact microwave for many years, so you are familiar with its use.
If it is constantly displaying "3.5" as you say and someone has not just partially input a Time and forgotten to Cancel the Input then it sounds like a printed circuit has gone bad...
Testimonial: "Thanks, Stan. It’s old. But new to me (in my used RV). It happened when I was cooking popcorn and pulled the door open before it finished a timed run. I didn’t reset or clear the cook time. Next morning it was unresponsive. I unplugged it a couple of times. Same problem. 3.5 and then 2:00 minutes of cooking. One time it acted like it was back working but it didn’t last. Thanks for your help!"
SOURCE: vent fan high comes on automatically with cooking
Right, that would be MCO10UW and the owner's manual is here.
The owner's manual does say this, of course,
"To prevent overheating from taking place, the exhaust
fan is designed to automatically turn on at a low speed if
excessive temperatures occur. Should this happen, the
fan cannot be manually turned off, but it will
automatically turn off when the internal parts have
cooled. The fan may stay on for up to an hour after the
range and microwave oven controls have been turned
off."
That;'s standard on microwaves.
But these models do have a separate internal cooling fan (which should run any time you microwave) plus the hood vent exhaust fan, which should only run when you select it, or if there is an excessive stovetop or under-hood temperature.
So if it comes on whenever you microwave, that is incorrect.
When that happens, it's usually a defective vent thermal switch (a.k.a. hood TCO).
But since it's brand new, I would certainly contact Magic Chef about this. If it's in need of repair, they will fix it free, assuming the oven wasn't physically damaged.
For more help from Magic
Chef / Ewave see here or their contact page.
For Magic Chef
in Canada call 866.587.2002
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
SOURCE: My microwave keeps blowing the fuse upon hitting the start button
you have one of three problems (H.V. diode shorted or leaky, H.V.capicitor shorted, or the magnrtron tube is beginning to draw excessive current)if thats the case its not usually worth spending that for the mag.,the other two items aren't that expensive
SOURCE: I have a Magic Chef microwave model mco153sf. The
HI. This is , indeed, an issue within the touch pad circuitry. it is damage, and will require replacement. I have located a replacement touch pad. Use the link below to access the touch pad. You can order the pad on-line, by clicking the link below.
CLICK HERE
SOURCE: Magic Chef Model #MCO160UW
Call 888-775-0202 Magic chef they will replace the part free of charge even if its not longer under warranty
