SOURCE: some jets are clogged
the outer ring on the out side will unscrew, just be gentle and you may have to use a large pair of channel locks, plyers, but don't grip the plastic to hard so you don't scar the plastic
SOURCE: I have power to the spa, but it won't power up
there are at least two separate circuit breakers feeding your spa and two reset buttons. the circuit breakers are located a few feet away from the spa in an electrical box.
the reset buttons are in the mechanical space of the spa where the pump and heater are located.
SOURCE: I have a catalina spa with BALBOA CONTROL PANEL
Where are you from?
If you live in the UK give me a call/email as I have worked on lots of Catalina Spas over the years.
http://hottub.synthasite.com
Regards,
Ian.
SOURCE: Balboa vs500/501/502 gs500/501/502 I just refilled
A lot of times you can get an air lock as the spa fills. All you need to do to fix this is open the drain valve for a few seconds till it runs just water and no air. Or start the pump wile the drain is open. This should fix your problem. Good luck.
SOURCE: I need to replace my
The best suggestion in this case would be to replace the spa pack and upgrade. this is a really old system. You can replace the entire system for around $500.00 and have the latest working technology along with a new topside panel, overlays, heater, system, etc. The Balboa Value Pack Retrofit kit comes with everything you need along with cables. Since you have Weslo with an oval panel, the best suggestion would be the Balboa 54219-Z Value Pack Retrofit Kit. you can get it online by clicking on the link I have provided.
Hope that helps.
Balboa Direct
