Question about HP Air Tools & Compressors
What is the RW1504ST-CP 1.5 HP compressor swith wiring orientation?
Why doesn't my rockworth compressor fill up when it's running it's brand new
This could be an assembly error at the company. There are three valves in a compressor, one is an intake, one is an exhaust, one is an unloader. The easiest way to check is to put your hand on the intake air filter to check for suction. If there is suction then the valve is ok on the intake, if it flutters then it is bad or missing. Locate the on off switch and there should be a valve that unloads the pressure from the compressor, see if that is leaking.
May 05, 2016 | Rockworth Factory-Reconditioned...
HP Cp compressor display on the screen "motor overload". What is the cause?
well over pressurization
pump is going bad and trying to lock up
Nov 20, 2013 | Air Tools & Compressors
My benq dlp mp515 swithes on and goes off after few seconds, wht to do?
test the power cord for loose wires or break use the multimeter 2) test the fuse loose or c.breaker loose wires 3) main switch for faulty or loose wires resolder. 4) if the bulb is o.k or the filamente is break or faulty.
God bless you
Oct 29, 2013 | Hitachi CP-X260 LCD Projector
Sperre air compressor lp safety valve blowing pressure 15 bar normal pressure is 8 bar hp valves and gaskets new
sir i need control drawing for sperre compressor electrical schematic(415 volt motor,pressure switch,thermo swith,drain valve,level switchand alarm( iacms)
Dec 19, 2010 | Air Tools & Compressors
Just bought a campbellhausfeld fl3307 compressor at an auction did not realize that it has mc94 2 hp moter which is wired for 230volts but my garage is not On the compressor it says engine can run on 120...
The wiring diagram to change the voltage is on the name plate on the motor. The motor leads are numbered. Go by the diagram and reconnect the numbered leads the way it says for 'low voltage'
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 23, 2009 | Air Tools & Compressors
Air conditioner does not work. I turn it on and it tries to start, will not start, turns off. When I turn the thermostat off you can hear a click back by the A/C unit. This is on an 03 Weekend Warrior...
the click you hear is possibly the contactor switch on the unit. This swith is activated by the thermostat which in turn sends voltage to the compressor. First things first, You need to check the contactor swith to insure you are getting power from the switch on.. Activate the thermostat the contactor will activate you shoud get the same voltage reading from l-1 and l-2 as you get from the t-1 t-2 sides of the contactor. if these readings carry the same volts then your problem is towards the compressor. Next item to check is the capacitor. this is a round or oval shaped metal cylinder that has several wires going to it, Some of these capacitors are dual, in other words they run both compressor and condensator fan motor in one unit sometimes each peice , compressor, fan motor, has a seperate capacitors If it is a dual capacitor the will be 4 or more wires going to it. since these aren't as costly I would recommend that you replace the capacitor and see if that has cured your problem., If it hasn't then you are possibly looking at a bad compressor and an a/c tech would need to be called to check that for you. Good Luck
Dave
Jul 17, 2009 | Dometic Rooftop RV Air Conditioner
HP 1402 All-in-one problem
four problems for sure.check out 1 by 1.
1)either the power outlet itself is faulty.
2)either the power cord wire is faulty.
3)either the adapter in which the power cord is fitted is faulty.
4)and last but the costly 1 the jack of the printer in which the power wire is inserted is faulty internally.
Oct 21, 2008 | HP PSC 1610 All-In-One InkJet Printer
Air Tools & Compressors Logo
37 people viewed this question
Top HP Air Tools & Compressors Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Eric Sutherland
Are you a HP Air Tool and Compressor Expert? Answer questions, earn points and help others
