Will not cool at all
SOURCE: Freezer stays cold, but not fridge
i had the same proble open freezer door and unscrew back plate if coils are iced up its eather a sensor on tot or the heaters lond tubes you can see if all iced up get blow dryer out to defrost
SOURCE: freezer staying cold, fridge is not
You need to replace the refrigerator evaporator fan motor assembly.
SOURCE: kenmore refridgerator model 363.9752711 freezer
sounds like the circulating fan is wearing out.
SOURCE: fridge and freezer not cooling properly. bottom s...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong.
If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
68rjszndh
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
