Receive Mode Setting
On the operation panel, press the following buttons to select the appropriate receive mode.
- Press <Fax>.
- Press <Menu>.
- Press the right or left arrow button to select [Receive mode set], then press <OK>.
Press the right or left arrow button to select the receive mode that best suits your needs, then press <OK>.
FAX ONLY MODE: When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only.
MANUAL MODE: When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually.
ANS MACHINE MODE: When you want to receive voice messages on your answering machine and receive faxes automatically.
FAX/TEL AUTO SW: When you want to receive faxes automatically as well as voice calls.
DRPD: When you have subscribed to a DRPD service with your telephone company.
- Press <Stop/Reset> repeatedly to return to fax standby mode.
Solution:
Changing the TX report MP530
Change the TX Report
1. Press the <Menu> button to display [FAX SETTINGS].
2. Use the [
] or [
] to select [TX SETTINGS] then press <OK>.
3. Use the [
] or [
] to select [TX REPORT] then press <OK>.
4. Use the [
] or [
] to select [PRINT ERROR ONLY] or [PRINT FOR EACH RX] then press <OK>.
5. Use the [
] or [
] to select [YES] or [NO] for [ATTACH TX IMAGE:] then press <OK>.
6. Press <Stop/Reset>.
Changing the Paper Size, Type and Source
Changing the Paper Source
Before
printing, confirm that the location where you have loaded paper is
selected as a paper source. Press <Feed Switch> to change the
paper source.
(A) Auto Sheet Feeder Lamp
(B) <Feed Switch>
(C) Cassette Lamp
Note: Press <Feed Switch> so that the Auto Sheet Feeder Lamp lights when loading paper in the
Auto Sheet Feeder and the Cassette Lamp lights when loading paper in the Cassette.
You can also select the paper source with the printer driver when printing from the
computer.
Changing the Page Size and Media Type
Note: The asterisk <* > on the LCD indicates the current setting.
1 . Press <Paper>.
When you do not need to change the page size, press <OK> to proceed to step 4.
2 . Use
to select the page size: A4 / B5 / A5 / 4x6 / 5x7 / C-CARD / 8.5x11 / 8.5x14
3 . Press <OK>.
4 . Use
to select the media type: PLAIN / PHOTO PRO / PHOTO PLUS / MATT PHOTO / GLOSSY
Note:
In order to obtain optimal quality print results, when copying
photographs, use Canon-recommended Photo Paper Pro or Photo Paper Plus
Glossy.
5 . Press <OK>.
Entering the Date and Time
Note:
When your machine is connected to a computer with the MP driver
installed, even if the date and time are entered from the Operation
Panel of the machine, the date and time will be read from your computer
every time you start the computer, turn the machine on, or disconnect
and connect the USB cable. When using your machine connecting to your
computer, set the date and time on your computer precisely.
The
date and time will be reset when you disconnect the power cord or there
is a power failure. In this case, you can set it again on the machine.
Alternatively, it can be read from your computer and set on the machine
by connecting the machine to your computer with the MP driver installed.
1. Press [FAX], then press [Menu].
2. Use [
] or [
] to select <USER SETTINGS>.
3. Press [OK] two times.
4. Use the numeric buttons to enter the date and time (in 24-hour format). Enter only the last two digits of the year.
Note: If you misentered the date and time, use [ ] or [ ] to move the cursor under the number to enter the correct number. Three formats of date are available.
5. Press [OK].
6. Press [Stop/Reset].
I hope it helps!!!
Lost my instruction manual for MP530. Need specific instructions on how to change date/time on FAX. It should not be that difficult IF it were on the menu.
Needless to say, this is my first and last Canon product. Am set up to print wireless and if I'm attempting to print off multiple pages, the printer stops. Must reboot internet connection, etc. A real pain.
