We can't change stetting. example we can't change drying time. We think the circuit board is bad? Is there a bypass or something we change
    Top Expert:
  • Televison & ... Master
  • 61,875 Answers
TV'S DO NOT WORK AS DRYERS
Posted on Jan 24, 2019
2 Suggested Answers
SOURCE:
aasc
  • 1606 Answers
SOURCE: GE PSS25MGMCAA refrigerator - Bad circuit board??
You need to change the board . Part number WR55X10656 . The board relay , cannot be changed . Power surges , dirty condensor coils , and usage , are the most common causes , for board failure .
Posted on Sep 24, 2009
Why is there No sound in bypass mode?
I have found this problem on several PXC 450 headsets and it can be solved by resoldering the bypass switch pins on the circuit board. We use about 25 pairs of these headsets and although they are excellent they can suffer from dry joints mainly on the switch but I have found a surface mount resistor in one case to be the problem.
To get to this board you need to unclip earpad on side containing switch then undo a number of philips head screws to reach the circuit board under the speakers then unscrew circuit board resolder and re assemble. Good luck.
Apr 28, 2014 | Sennheiser PXC 450 Headphones
LG 32LH20 colors distorted
The only thing I could think of is a tcon board, if that isn't what it's called by that tv, it's also called something like a LCD digital board to timing board. Usually it's right behind the display inside.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/erik_3934b541f17c4e99
Dec 11, 2012 | LG 32LH20 - 32" Class / 720p / 60Hz / LCD...
So what do i do if when i turn my onkyo tx-sv454 receiver on it says protect and then shuts off? How do i fix that or get around it? please help me....
I don't think you can fix it, unless you're skilled with electronics. Possibility that something has occurred internally with a circuit board etc so the system shuts down in order to protect itself from catching on fire etc. Get it services. Might not be too bad of an issue, but certainly not a bypass.
Mar 02, 2011 | Onkyo TX-SV454 Receiver
How to reset control panel on model 587.1517 kenmore dish washer
From what I have read elsewhere, the interrupt *may* have something to do with a thermostat circuit cutting out if the entry hot water is too high ( more than 145F) - it seems like a buggy safety feature i.e. the circuit board thinks that the water heater is overheating. The makers have apparently made changes to the control board to fix this bug but it costs serious $$$ to get a repairman in and buy the new board.
I prefer to use the reset code, and keep my water temp lower when using it.
Feb 20, 2011 | Kenmore Dishwashers
Washer won't start - displays f and then dl flashes
HI,
The FdL code is saying that the circuit board that runs the washer (CCU board) thinks there is something wrong with the door lock. Often times it's not the door lock but bad connections at the CCU. Whirlpool had some bad quality control with the CCU circuit boards and the end result was cold solder joints at the spade connectors and the relays (there's 5 relays on the CCU board) With this repair you need to remove the circuit board from the inside, top, back of the machine. Mark all the connections before you take them out then remove the entire plastic case with the circuit board inside. At this point you can resolder those points I spoke about or take the board to a good appliance repair shop along with this response and they should be able to help you out. Good luck.
Jan 13, 2011 | Whirlpool Washing Machines
Sep 23, 2009 | GE Refrigerators
Dryer works when it feels like it
If it shuts off in middle of cycle (like completely powers off with no led lights on) then your board is more than likely bad. Those boards are pretty expensive if not under warranty. I dont think it would be your thermostat because that its part of the heating circuit and then you would not have any heat at all. Try calling up sears to get a warranty, just say that the unit is working fine and you just want to get a 1 year warranty for the time being...if they dont send anyone to check it out then go for it and like wait like 2 months or so and when you made sure its covered and the warranty has taken affect, just call and say theres a problem with the dryer. Just an idea to try to get around the repair. I think the boards go for like 300. I would think its a board issue if it powers off. hope this helps.
Jul 26, 2009 | Whirlpool GEW9250 Electric Dryer
DeWalk DC500 wet/dry vaccum doesn't work
Vacuum works with the battery but does not work with 120 volt. Every time I plug it in it blows the internal fuse. I have replaced the fuse inside the vaccum several times and every time i plug it in it blows. What do you think it could be?
Feb 21, 2009 | Dewalt DC500 Canister Wet/Dry Vacuum
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
