I can see the ice clog fully blocking the pipe from the opening at the outside end above the elbow. There any no icicles, the clog is inside a couple inches from the opening. The furnace shuts down because the exhaust pipe is blocked. I cannot tell how thick/deep is the ice clog. I see water seepage on the other end of the exhaust pipe in the basement where it connects to the furnace -- evidently from partial melting of the bottom end of the ice clog. I'd like to remove the clog. How to do it? Shall I pour hot/boiling water? Use a hair dryer? In any case if the clog starts melting it may fall further down into the pipe and some water from melting will flow down to/into the furnace. Is it a concern? Any other ways to remove the ice clog? This is the first time in 15 years a clog has formed. How to prevent it in the future?
SOURCE: RHEEM HIGH EFFICIENT FURNACE-BACKDRAFT SHUTTING IT DOWN
Build some kind of barrier outside so the wind doesn't hit the vent. A piece of plywood before it or a big box around the vent. There is a pressure switch that the wind is messing with. It is a safety and necessary for the furnace to run properly.
SOURCE: water from the ice maker
Sounds like the water valve For the ice maker fill is leaking. these are solenoid type usually found at the back bottom outside of unit. turn water to this valve off at connection in wall . You can have that valve replaced
