SOURCE: Canon iR-2016 System erro E007
The erreor code E007 has to do with the fixing ***'y upper film ***'y or roller. It is saying that the film is not moving in and out of "HP" Most of the time it means that the fusing film is torn and not moving properly. If you are getting paper jams in the fusing area and or unfixed or smeared copies. You most likly need to have the fusing film ***'y replaced. It could also be that it is out of place and needs to be readjusted. The only problem is that it's a little tricky to get to and not a bad idea to have a new film to replace the old one while you have it out. Good Luck
SOURCE: Canon photocopier 1600 Cleaning Blade not cleaning properly
Perhaps the pblm is not in "the drum unit"... check the mirrors may be are dirty.
SOURCE: Canon IR 3300 model - Paper Load Liver problem in second tray
The tuck tuck sound is sound of paper pick up claw in pick up mechanism of second paper drower.The case is that the pick up clow is worn out and may be broken, so you need to replace it.To replace it you must remove complete pick up unit from the right side of copier, if you are not service technician do not do it by yourself it could be complicated if you do not know exact schedulle of parts and what does it doing.
SOURCE: ir 8500 cannnon copier black shade on paper
hi dude i dont think u have problem with drum cleaning blade coz it not making trouble for me from last 5years.
just replace the crona wires both charge and transfer and clean the whole scanner mirors .
thanks
SOURCE: sir, my canon ir 400
the code 803is for faulty exposure lamp or fault in composite power supply(the power supply to exposure lamp is not sufficiant to operate the lamp).to remove exposure lamp, remove copyboard glass,remove back cover ,slide scanner in the line of rear exahaust fan at the right side of scanner, remove rear exahaust fan, remove lamp holder(one screw).slide out lamp on the rear side replace new one and reverse the whole process.
