turn both phone bluetooth and speaker bluetooth off. then turn them back on. the speaker's light should be flashing indicating its searching for a device to pair with. as its flashing make sure your phones bluetooth is visible and searching. they will pair and your phone will tell you and the speakers light should quit flashiing and just remain on.
Hi, what makes the speaker of your cell phone not working is because the flex of the cell phone is damaged and it controls the function of the Speaker.
The flex look like a thread like object inside the phone. it connects the front sliding board of the phone to the lower sliding board of the phone. It controls the function of the RInger and the speaker of the cell phone.
When the flex gets damaged, it affects the ringer and the speaker of the cell phone.
When you replace the flex of the cell phone, the speaker will function again.
Hi, when your not getting sound out of the front speaker,is because the speaker inside the phone is damaged and will need to be replaced with another one.
Problem like speaker problems are caused by Flex being bad(if it's a sliding phone), when a phone drops on the floor, or when the life span of the speaker has finished it will go off by it self.
Note: If it is a sliding phone that uses flex inside of it, you will need to replace the flex because the flex controls the speaker inside the phone.
So instead of replacing the speaker, you will need to replace the flex inside the phone.
The flex is a thread like object that is connected to the board of the phone and the screen of the phone. And also controls the function of the speaker inside the phone.
open the phone, clean the surface of the speaker, read the speaker with a meter, if it is working, put it back on and couple the phone but if it does not work replace the speaker with working speaker.
this will erase ur contacts on the phone and perhaps sms;s too that are stored on the phone memory, but it may just make the speaker work too. if it stil fails, change the flex connector and ur phone speaker will work fine.
HI,
When we use our phone for a long time in talking,the speaker of our gets stuck(The diaphragm inside gets over vibrated leads to speaker damage).
The only way this problem is to,by taking your phone to Nokia care centre.
OR
If you are aware of your phone,you can open your phone and replace the speaker of your phone.
BUY:
Speaker :Nokia Mini Speaker MD-8
Output: 2x1 watt
Just press and hold the "phone" green buttom for about 2 seconds. The main speaker is enabled. The same procedure works when during a phone call, to enable a hands-free operation, or when listening to windows media player.
