Washing Machines Logo
Lesroy Arthur Posted on Jan 21, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My frigidaire top loader washing machine still collects water when it's on the spin cycle what can be the problem?
Tom Chichester
Level 3:
Top Expert:
  • Frigidaire Master 62,329 Answers
  • Posted on Nov 08, 2020
Tom Chichester
Frigidaire Master
Level 3:
Top Expert:
Answers
62329
Questions
0
Helped
671498
Points
975369
Part of normal operation
5 Related Answers
Anonymous
  • 185 Answers
  • Posted on Mar 25, 2008
SOURCE: washing machine agitator & drum spin during wash cycle
check the dogs in your agitater
Anonymous
  • Posted on May 11, 2008
SOURCE: Frigidaire washing machine collects water behinf door seal
Frigidaire has several mfr defects with their new front loading machines. The detergent/bleach drawer retains water, the door often leaks, water does accumulate in the door seal and the spin has broken twice on us and the machin is only 15 months old! Repair is contracted out by Lowes to independant repair companies, who demand payment, even when Lowes says it is covered under warrantee. What a waste of a large amount of money! We will NEVER purchase Frigidaire or recommend their products to anyone.
Anonymous
  • 373 Answers
  • Posted on Jan 16, 2009
SOURCE: washing machine drum is very wobbly
* General tips
* Balance the load
* Level the machine
* Inspect the water pump for a blockage
* Inspect the coupling
* Inspect the transmission
* Adjust the drive belt tension
* Check the motor bearings
* Check the drum brakes
The above are possibly the general remedies for this problem.But possible if the problem still persists after this, possibly the drum bearings might have been damaged during the previous heavy vibrations.Please do post comments.Will be glad to help you out.Good luck.
Anonymous
  • 38 Answers
  • Posted on Dec 29, 2009
SOURCE: burning smell during spin cycle on frigidaire washing machine
Open lid as you would load clothes and hold the inner drum with all the holes in it. Give it a manual turn left, then right. If it spins in both ways the main bearing is gone. This is not a DIY because the new bearing has to be pressed on at a machine shop, or an appliance repair shop.
Anonymous
  • 4 Answers
  • Posted on Mar 20, 2010
SOURCE: washing machine won't spin and drain
the drain pump is not working,after wash cycle the washer should drain the used water,if it does not function-all the next cycle will not commence.
Our frigidaire front loader washing machine does not spin and the clothes are still wet! Model FTF1240FS2. It seems to go through the cycle and pump the water but the drum will not spin. I checked the...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
2helpful
Washing machine won't spin and drain
3helpful
I have a mo# FTF2140ES0 front loader washer that won't spin
check the pump for a blockage,if the water cantget out of the wash tub,the machine senses this and wont spin out the load,also make sure to check both sides of the pump from the tub to pump and pump to house drain sides
2answers
My frigidaire top loader fills with water at the beginning of the wash...then nothing. it just sits there full of water.
Hi, could be your timer motor, timer or water level switch, first push timer knob in and manually advance to wash or spin cycle (program) then pull knob, see if machine operates, let me know, then i can tell you exactly what's problem.also advance timer, to spin cycle (program) machine should pump out water, or you can lower drain hose into bucket and empty machine, you should empty machine and try again, let me know what happened, we can solved this together. good luck.
After any wash cycle it stops; will not eliminte water or spin
First check the drain and screen to check for clogs. Also check drain hose. check to make sure door switch and wires are not loose. Look to see how many other sensor you have in the machine. You can test any sensors and wiring for current/resistance with an ohmmeter or multi-meter.
Hoover 750lb
if its a top loader check for timer/timer module fault.front loader check carbon brushes in motor
Frigidaire front loader
Can you hear the motor running? If so it will be the belt. If not simple could be the wiring..connection at the motor or broken wire. Brush's..very common at about 4-6 years depending on usage. or the controller.
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
