SERVICE MANUAL
SOURCE: monitor power shuts off without warning
You might check the filter capacitor on the power supply and see if it is swelling or shorted.
srich
SOURCE: Looking for service manual
GO TO MANUFACTERS SITE AND CHECK THERE , YOU CAN USUALLY DOWNLOAD A COPY IN PDF FILE FORMAT . ALSO IF YOU HAVE THE DISK IT ORIGINALLY CAME WITH A COPY OF IT SHOULD BE ON IT .
SOURCE: touch system not working NEC multisync 1550v
You have to install the nec driver for this monitor. I have the same monitor. Im looking for the driver now. There are 2 versions of this monitor with the same model # . You will need to find the driver to the touchscreen model.
SOURCE: NEC MultiSync LCD1765 won't power on
Look for bad caps with bulging top in the power supply first, post back what you see inside so we can guide you further, see example of failed monitors due to bad caps (after about 2 years): http://s807.photobucket.com/home/budm/allalbums
SOURCE: NEC MultiSync LCD 1560V+ 15 '' LCD Monitor touch-screen
How do you flip the screen on this lcd computer so it's side ways
