iFixitAug 1, 2014 - Hi Ifixit,. I've got a Panasonic th-p42ut30a plasma tv that has a fault with it. The standby light is on (red) but it doesn't come out of standby.Missing: l47dt50
PanasonicSMART VIERA® 47" Class DT50 Series Full HD 3D LED HDTV (46.9" Diag.) ... Issues Addressed: Solves issue where the Emergency Alert System is displayed on the TVhours after the termination of the message. Solves issue where the Emergency Alert System is displayed on the TV hours after ...
? 9:00
https://www.youtube.com/watch?v=EanHoWLLpxU
Nov 6, 2014 - Uploaded by Electronic Workshop
Panasonic TX-P42X50B No Picture Or Sound This plasma television ... TV repair, clicking and will not power on, loud snap,no picture, etc.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Visit the site named 'Electro-help' for
more details. Check this link and
select the site named above. View it
in 'Flip card' option, which can
be selected from the drop down box menu by the [Sidebar] tag, at the left top
left corner of the display window. It will make search easy. Some times, the
ads attached with each posts both at the right and bottom, might help you to
find the availability of spare parts. There are more than 640 posts to
different brand TVs now. Will be
updated daily. Faults to Pansonic Plasma s are given in detail. Pull up older posts there.
Hello.... First the bad news... Air Conditioning systems do not have a reset. Now the good news... The system could have shutdown due to low fluid... There is a pressure sensing switch in the line that respond to the "Low Fluid" condition.The reason it does that is so that the compressor does not get damaged and cause all sorts of other problems...
The fix... If it has shutdown due to low fluid the system needs to be serviced and it will start working as good as new... Take it to a repair shop with the proper equipment..
It means the fuser section (the Hot Part) has g,one bad to clear the code you will need to get into the tech mode. "Function", "3", Orignal Size "Legal" that order once there go to F9 Look for Fuser Reset then turn off the machine wait 10 seconds turn on if it comes back the fuser needs replacing or worse thre main board!
