SOURCE: Need Vista driver for NV-DS65
i have the same problem. if you could send driver for panasonic nv ds 65, i would be very grateful !
SOURCE: software for panasonic digital camera nv-ds65
I have uploaded the camera driver here.
http://rapidshare.com/files/151262301/Driver.rar.html
Un rar the file and press the setup icon in the file.
After this the computer will recognize the camera and you will be able to use for example the moviemaker program to capture (transfer) the movies from your camera.
You can contact me if you need a more detailed instruction
Adrian
SOURCE: vcr will not play tapes,it ejects the tape after a few seconds
This may be caused by the mode switch.
By the way it uses a K-Deck Mechanism.
SOURCE: Panasonic NV-DS65 500x it gives power red flicker
This is not the problem with that battery. That battery is using for the clock & date memmory. From your question not clear the problem. First you check the flickering condinously or after two or three or some another numbers flickering then giving some intervel then it doing again.
Any way I can give u a solution. Open the black cover remove the flex cable which is connected in between mechanisum and main P.C.B. & remove another flex cable which is connected capston motor & main P.C.B (which is big flex cable just closed to tripod fixing hole. Then clean with sprit & cotton bud. After five minute refixed it again. Mostely it should work. Try this if the problem is not solved tell the details of the flikering of the red light
K. R. Rajan
