Question about HP Office Equipment & Supplies
Paper creasing Hp laser jet 1300 printer creases the paper on the left corner
    Master:
  • 411 Answers
Check the rollers for adhesive residue or a sma piece of paper left in the guides.
Posted on Jan 21, 2019
Testimonial: "Checked and cleaned but that is not the culprit"
SOURCE:
Soulvisitor
  • 1113 Answers
SOURCE: printer is putting a crease in the middle of the paper
You need to have the fuser replaced, it comes out easy on these back cover just pulls off, and there is two tabs or long silver screws to undo fuser, remove it anf you will see that upper roller is worn, buy a maintence kit for this model which includes fuser and fit it yourself easy done instructions are included with kit.
Posted on Dec 01, 2007
Soulvisitor
  • 1113 Answers
SOURCE: Printed paper is creased
First thing to check is try it with a fresh unopened ream of quality paper, paper with too much moisture content, drys out and goes wavy when it runs threw the fuser roller at rear (180 deg), otherwise it will be the fuser rollers themselves causing your problem, which means that you need to replace fuser assy
Posted on Dec 05, 2007
Soulvisitor
  • 1113 Answers
SOURCE: OKI C5250 Printer
My informed guess without seeing print sample is that your oki needs fuser unit replaced. Look at orange rollers should br smooth no wrinkles.
Posted on Dec 20, 2007
SOURCE: paper has creases or is crinkled
We have had it worked on 2 or 3 times in the last six months and it is still doing the same thing.
Posted on Aug 26, 2008
  • 990 Answers
SOURCE: HP Laserjet 1300 paper creasing on printing
change toner cartridge will be OK!
Posted on Dec 16, 2008
Crease in paper when printing
Your information is a bit limited but we'll try anyway.
If the crease is a corner fold or a pressure line down the page, it will often be caused by something in the paper feed path close to the main drive bar in an inkjet or near the fuser in a laser printer. Have a look at the leading edge of the paper as it exits the printer for a nick or mark that may give a clue where to start looking. If there is a fold or crumple line down the length of the page, look at the paper pick up mechanism in an inkjet (usually the paper tray is a good start) or if it is a laser printer you should remove the fuser and check the fuser sleeve and pressure rollers. If you could let me know what the machine is and where the crease is I may be able to give better advice.
Jul 09, 2015 | Office Equipment & Supplies
Hp laser jet P2035N has a crease down the center of the page as the paper exits it is actually slightly raised so the print is smearing
Check to make certain that the fuser unit is not damaged. Often a crease or dimple is caused by foreign material on the fuser roller or the fuser is damaged. If the fuser is damaged, look into replacing the device, it may be cheaper than repairing the fuser.
Jan 31, 2013 | HEWLETT PACKARD - LASER JETS New - Hp...
PAPER IS FOLDED AT THE CORNER. I STOPPED THE PRINTER THE PAPER WAS CREASED WHEN THE PAPER WAS UNDER THE TONE CARTRIDGE WHEN I TOOK IT OUT CAN YOU TELL ME HOW TO FIX THIS PROBLEM. THANKS
You probably have a small obstruction under the registration assembly or the actual rollers of the registration assembly are out of position. I have had this before. Lift the metal flap with the green lifter on the right hand side, up and check for paper and if it is in the right position. Also make sure that the paper guides in the paper tray are snug up against the paper.
May 11, 2011 | HP Laser Jet 1320 Printer
The printer creases the paper top left hand corner
hi just check the inside one paper gear will be if it is creases measn that is problem
Dec 16, 2010 | HP LaserJet 1300n Printer
Paper comes out creased on one side
If the printed image is smudged, as well as creased, you might have a torn Fuser fixing film.
You will need a technician to fix that.
If it is just a crease, just check that
1. Your paper is not damp. Try a fresh packet of paper
2. The paper input tray guides are set to the width of the apaer, to prevent the paper skewing as it feeds.
Good luck.
Jun 21, 2010 | HP LaserJet 1012 Printer
Paper is crumpled, toner is not adhering in certain areas
The fuser is shot....this is the unit that uses heat and pressure to fuse the toner to the page. It is primarily when the pressure roller wears that you get crinkling and bad fusing, but I'm sure the upper sleeve has seen better days as well.
These days it is (sadly) cheaper to replace this printer with a new little HP -only around $100 or so.
*please rate me :)
Mar 17, 2009 | HP LaserJet 1300 Printer
OKI C5250 Printer
Dec 20, 2007 | OKI C5200n Laser Printer
Dec 05, 2007 | Samsung CLP 300 Laser Printer
32 people viewed this question
Clive
Clive
Thomas F. Schneider
