The app is searching devices and finds none i tried to do manual connection from phone settings, no luck
SOURCE: pairing motorola H500 bluetooth w/ nokia 6102i
you need to press and hold the on button on the headset, until the blue light stays on, then it will be in pairing mode. As soon as the headset is paired the blue light will go off and flash periodically. To turn off the headset press and hold button for about 3 seconds, it will flash 3 times then let go and it will turn off.
SOURCE: Trying to pair omnitech 2.0 bluetooth headset without manual
before attempting to pair your headset with another device, be sure that the bluetooth headset is in the off position
Any questions email: [email protected] Subject: omnitech bluetooth
SOURCE: pair motorola H500 to samsung eternity SGH-A867
I have had this problem too. Here is what worked for me.
1) With the Motorola H500 OFF, press and hold the talk key until you see a steady, non-blinking blue light.
2) Keeping that button pressed, turn on the bluetooth on the samsung eternity.
3) It should now find the H500, click on it and select connect.
4) Put in a pass key (I just put in 0000) and your done.
