The first thing I would try is swapping the speaker wires on the back of the amp and see if the problem moves as well. Then you know what your speakers or speaker wire. If that's not the case, then try switching the left and right
from your sources and see if the problem follows. This should get you a pretty good idea of what's wrong
Testimonial: "hi Erik, i have tried all these ideas and the problem is with the amp. i am really looking for some input from others who have had similar problems and that have identified a common failure in a specific component that i could replace rather than go to a repair shop. thanks for your input."
SOURCE: Using a tube pre amp with my CA Azur 640A?
There are many answers to your questions but Ill have a go with the basics...
Audio connections should be matched.... its called Frequency impedance,.... to get a signal along wires or cables (or Fibre) the Impedance of the cables and wires must be matched to the device they are connected to transfer the signal along the cables without distortion...
Manufacturers provide many sockets on the input side of amplifiers and preamplifiers to allow the consumer to connect various devices of different impedance.
They label these inputs like CD, or Tuner, or PHONO etc etc,
That means if you have a CD player it must be plugged into the CD input socket then the impedance will be correct and the sound will transfer along the CD cables correctly, without distortion..same with the Phono input etc...
You will find on the sound output to the speakers terminals are also labelled 4-6ohm, or 8-10ohm, these are the impedance expected for the coil ratings of the speakers them selves and its important to get the correct speakers to the correct out put terminals...
In your case all you have to do is follow these simple rules and all will be well....you say you have a squeeze box well there probably isnt a port labelled squeeze box so you need to experiment and try out each input port for the squeeze box to see what input gives you the correct sound output...Watch the Phono inputs as these are very sensative to input sound levels and must be treated very carefully as they have a double stage of sound amplification and as such you need to have the volume right down when connecting up the Phono inputs then increase the volume carefully after the cable connections are completed.
If you follow these rules then all will be well,,,,there is no difference if the Pre amp or Power amp is valve or transistor or FET or has IC outputs to the speaker the same impedance rules apply..just treat it as a box with input and output terminals and all the impedance will be taken care of for you...if you read the lables...
You need to connect you signal source to the Preamp inputs the out put from the Preamp connects to the power amp input then the power amp output goes to the speakers. this is a basic configuration for sound systems, there are other variations but are outside this discussion.
Cheers From YUBEUT
SOURCE: I have a Cambridge Azur
Yes, you are right. That's a protection feature to prevent burnouts. Typically it appears when your speakers are sucking up a lot of load from the amp. Please check your speaker impedance and the amps' output impedance and ensure the wiring are properly done. Some amps are soo sensitive that they may cut-off after certain level due to overload.
SOURCE: cambridge azur amp 640a working
Looks like the fuse blown.. or the classic symptom of electrical fault inside the amp. 640A uses a sensitive protection circuit often ends up in this irritating situation. Normally, there is nothing much you can do, but just check your wall plug connection for Open Ground or Left & Neutral reversed issues. If the wall plug is free of error, then you should better contact CA technical support.
SOURCE: I have a Cambridge Audio azur 640A amp. When
Switch the channel on the phono to isolate the problem within or outside of the amp.
