Question about Amana Heating & Cooling
How to bypass f1 thermostat error code on Amana ptac unit
  • 4,345 Answers
F1 - Control Board Failure - Replace control board (ERC). F2 - Oven Temperature Too Hot - Replace oven temperature sensor. F3 / F4 - Shorted or Open OvenTemperature Sensor - Replace oven temperature sensor. F5 / F6 / F8 - Control Board Failure - Replace control board.
Posted on Jan 20, 2019
SOURCE:
oscarn
  • 110 Answers
SOURCE: ptac fan keeps blowing
Try setting the fan control to "AUTO" this will cause it to cut out with the compressor.
Posted on Sep 07, 2007
  • 6 Answers
SOURCE: amana ptac shuts on and off constantly
your control board is shot and your ac can't tell the room is cold enough. 1-888-855-9987
Posted on Sep 09, 2008
  • 142 Answers
SOURCE: Amana PTAC PTC093A35AA won't blow heat
The reset button is located behing a panel on the front of the unit that is labeled Heat Reset. If that label is gone then look around, it is a small hole, small enough for a paper clip to fit through.
That being said, I have 137 of these units in one of my hotels and have not had a single one needing to be reset. You probably are going to need a new control board kit. These can be purchased from Amana. They are $130. Make sure that you have pulled the heater coil out and inspected it first. Also, there was a recall years ago where Amana was supposed to contact and send out new voltage switches. These are the round black things that the Brown heater wires connect to on the upper and lower side of the heating coil. You should also try to replace those if you find the coil in good condition. I have had those resolve heating issues. Most of the heating issues were a result of a bad relay on the control board though.
Please remember to rate this fix.
Posted on Feb 12, 2009
  • 4 Answers
SOURCE: What does the code F1 & F6 mean for the Amana
These codes signify black (F1) or yellow (F6) thermistor problems. May need replaced.
Posted on May 07, 2010
  • 3 Answers
SOURCE: Amana PTAC
I know this is late but I had to add a solution to this problem since I had the exact same problem and was able to solve it. The probelm is not your control board. On these units, the heat pump compressor will not kick in unless the temperature you set on the control panel is within 2-1/4 degrees (or 4 degrees depending on your unit model. Otherwise, the unit locks out the compressor until the electric heat coil bring the indoor temperature up to that level - and then will switch the compressor back on for heat pump operation. So the problem is not the control panel or the compressor, it the electric heat coil. The coil has two manual limit switches on it that may be tripped and should be checked. The coil can be easily accessed by shutting down the power, removing 4 screws around the air outlet, pushing the screen up and sliding the panel out the top. The power wires can remain in place while the limit switches are reset. Hope it works.
Posted on Nov 06, 2011
Amana Wall unit blows cold air before heating
the unit works by chilling air and the byproduct is heat in the compressor, this is used for heating in the winter and then reversed in summer to blow cold air. It has to blow cold and warm up before it can blow heat.
Mar 17, 2017 | Amana Heating & Cooling
Amana ptac unit that cools four minutes and shuts off?
thermostat most likely. running to long to be safety issue.
Jun 15, 2015 | Amana Heating & Cooling
Where can I find a troubleshooting manual for the DS01E amana t-sta?
http://www.amana-ptac.com/Portals/3/PTAC/PDF/DigiSmart%20DT%20DS%20DD%20Wireless%20EMS%20Installation%20Instructions%202010.pdf
Feb 19, 2015 | Amana DS01E - DigiStat Thermostat with...
Troubleshoot ptac units
If this is a heat pump unit, the defrost thermostat may be stuck closed
Dec 17, 2013 | Heating & Cooling
My amana ptac is not heating....the code "np" is displayed....how do I correct this...we just installed the unit and know little about operation. Thanks
I don't see this error code in the manual. I do see nP as an error code for Window Switch lockout. I just had this happen to me and they had me reset the control board.
Remove case, flick master switch to OFF for 10 seconds. Press Heat/Cool same time turn switch back on HOLD until off light comes on.
You should be fixed. Just had to do this for my unit. I was playing around with the settings and turned on the window switch option by accident.
Feb 02, 2013 | Amana In Wall Install Kit For Digismart...
Installed Amana PTAC DigiSmart unit in a patio room, a entertainment bar is located about three feet (3) in front of unit and not the room. The unit only heat and cool the area between unit and the bar...
I have seen this happen many times and if you cannot relocate the bulb of the thermostat to keep it form short cycling, I have mounted a wall thermostat and disconnected the thermostat in the PTAC and wired it in to the wall stat. You may have to install a wall stat in the center of the room away from the bar.
May 15, 2011 | Heating & Cooling
Amana PTAC unit when in the heat mode only blows cold air.
check heater coil may be faulty may be a faulty thermostat or temp sensor
Dec 08, 2010 | Amana Heating & Cooling
Remote Thermostat
call the amana dealer nearest to you order one
Jun 06, 2008 | Amana PTH123B25AJ Heat Pump Air...
Heating & Cooling Logo
59 people viewed this question
Top Amana Heating & Cooling Experts
Donni Steen
Bill Long
Dennis Boxerman
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
