Question about Casio Fx-9750gii Graphing Scientific Calculator
I am trying to graph 5x+3y=15 on my my casio 9750gii calculator but I keep getting the Syntax error. What am I doing wrong?
    Top Expert:
  • Casio Master
  • 1,533 Answers
SOURCE:
  • 8081 Answers
SOURCE: How do I graph an equation such as y= 5x + 2?
Turn calculator ON. If you do not see several icons press [MENu].
Use arrow to select the [GRAPH] application and press [EXE].
In the entry screen, the line with Y1= is highlighted. If it is not, use arrow to highlight it.
Press the right arrow, the highlighting disappears leaving you with Y1= and the blinking cursor.
At the position of the cursor enter 5 [X, theta,T] key under the [ALPHA]. On the screen appears 5X, complete you equation +2.
Press [EXE] to store function.
If you want to draw other functions, it is time to do so on that screen.
When done press [F6:Draw}.
If the screen does not show a lot of the function, you can use the arrow keys to pan the graph.
You can also press [SHIFT][V-Window] to set the window limits.
Hope it helps.
Posted on Oct 11, 2009
Testimonial: "Thank you so much!!!"
  • 8081 Answers
SOURCE: graphing syntax error
To draw graphs.
  1. Turn calculator ON (isn't that obvious?)
  2. If you see no icons, press [MENU]
  3. Use arrow to move focus on GRAPH and press [EXE]
  4. By default, the graph type is Y=
  5. Enter your equation on line Y1=, use the [X,theta,T] key to enter the X-variable
  6. Press [EXE] when finished entering a function.
  7. Enter other functions if you want.
  8. When done, press [F6:Draw].
  9. If you do not see a big portion of the curve you can press [SHIFT] [F2:Zoom] and select [F5:Auto]
I am enclosing screen captures. The screens you see may not look exactly as on the FX-9750G, but all menu commands you have to execute are accessed by the same key sequences.
This last one is obtained with the Zoom: Auto
Posted on Mar 02, 2010
SOURCE: i do not know how
Hey it is. Okay, so start with a equation: say, y = -(1 |x|). Now type y = -(1 , then press the [OPTN] button, next to the shift. Next press the [NUM] button or F5. The first menu button should be Abs or absolute value. When your done it should look like this. y = -(1 Abs (x)) then graph it.
Posted on Aug 30, 2010
  • 102366 Answers
SOURCE: How do I find absolute
You'll find the absolute value function in the MATH menu.
Posted on Feb 26, 2011
  • 8081 Answers
SOURCE: am trying to calculate corelation on a Casio
Press Menu.
Use arrows to highlight STAT icon and press EXE.
Enter your data in two lists (x-values in L1, Y-values in L2)
Press F2 to activate the CALC Tab at the bottom of screen.
This is what you see.
Press F3 to activate the REGression tab.
This is what you will see: the TABs at the bottom of screen.
Each tab corresponds to a regression model: X-linear, X2 quadratic, etc.
If you press F3:X^2, you get the following
You see the parameters of the regression equation, the coefficient of determination r^2, and the Mean Square error. No correlation coefficient is defined for this regression model.
For other models like linear, logarithmic, power and exponential regressions, the correlation coefficient is defined and is thus displayed with the regression equation. It is the r-value.
Posted on Aug 01, 2011
I don't know how to graph absolute value functions on Casio fx-9750GII.
When it is time for you to put an expression in absolute value, press the OPTN key, then F5/Num, then F1/Abs. Open parenthesis, input expression, then close parenthesis.
For fractions, use the key with the symbol a b/c.
A little friendly advice, please do invest some of your time reading the manual. Most Casio graphing calculators work the same way. What you learn on one, works on another.
Aug 19, 2017 | Casio Office Equipment & Supplies
Casio fx-9750GII is giving the wrong answer, is it broken?
Check the calculator with a simple 2X2 matrix that you can invert by hand easily and see if it gives you the wrong inverse for it. It is also possible that YOU made the mistake.
Jan 03, 2016 | Casio FX-9750GII Graphing Calculator
When I try to graph it says argument error
Your function is not correctly defined. If graph is function y=f(x), variable must be x; if graph is polar, variable must be theta, and if graph is parametric, variable must be t. This does not cover all possible cases. Check the graph type and the definition of the function.
Mar 16, 2015 | Casio FX-9750GII Graphing Calculator
I have a casio fx-9750 g2.Whenever i try to dra w a graph it always get a syntax error the manual has not helped.kindly assist.
Please give the exact examples you were trying to graph. The syntax error points to an error in the input line, such as using the minus sign instead of the change sign (-).
Aug 08, 2014 | Office Equipment & Supplies
How do i graph three equations on my calculator
Your calculator cannot, natively, perform 3D graphing.
Jan 28, 2013 | Texas Instruments TI-84 Plus Calculator
My Casio fx-9750GII wont dispay a table
The message dimension error usually refers to instances where two lists do not have the same dimensions (number of elements)
I checked and the calculator gives condition error. Check the type of function you are creating a table for. Choose the type y=
Nov 05, 2012 | Casio Calculator Graphing FX 9750GII...
How do i use the fx-300es to graph
Sorry but you cannot do that. This is not a graphing calculator. However you can generate a table of values for your function (MODE TABLE) and use it to graph the curve by hand (pencil and paper).
If you need a Casio graphing calculator, one of the cheaper ones is the Casio FX-9750GII. Equivalent Texas Instruments calculators are the TI83PLUS/TI84PLUS.
Aug 31, 2010 | Casio fx-300ES Calculator
Casio Fx-9750gii Graphing Scientific Calculator Logo
32 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Colin Stickland
Colin Stickland
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
