My QFX-SBX-881500BTL bluetooth 15inch Bass Thumper PA BLUETOOTH speaker sounds like its going out but my friend said itz probably a fuse i dont kno wut to do
SOURCE: relating to bluetooth
If I got it correctly you have a built in wireless bluetooth adapter but you did not get the software and possibly the driver either when you bought the laptop. If it is a a built-in bluetooth adapter then you need to look for your laptop manufacturer's site and find you laptop in the downloads section and you can download their own software and driver from the Vista section.
If you are using an outside dongle then almost for sure you'll be able to use BlueSoleil, though if you could not get the dongle recognized then you still need to find drivers to it. You can most likely download the Vista driver from the manufacturer's site.
If you name the manufacturer /of the laptop or the dongle/ I'll help find the driver or software for you.
SOURCE: my windows r stuck and they wont go down at all i
Start by checking the window fuse in the fuse box.
SOURCE: i lost the hand book and i dont kno where my fuse goes
Fuses are generally located under the dash on drivers left and under the hood beside the battery. The covers should hold the fuse info.
SOURCE: best amp for two l7 15inch speakers are 4 ohms
i personally like the audiobahn a.k.a. cheater amps ill go with the A2300hcx model
SOURCE: i dont kno wut wrong whit dat back ligth and
There it a switch that controls the brkae lights Its on the upper part of the pedal you have to look up under the dash board The pedal has a rod that attaches to it with a pin that has a clip on one side The switch is right there the pin runs through it Remove the clip slide out the pin and the switch comes out There is also an adjustment for the switch you may not need to replace the switch the adjustment may correct the problem If the switch is bad there easy to get at any parts store and about 10 dollars good luck
