Hard to say, you could have a bad keypad, or you could have a shorted oven sensor. If your microwave is still heating on some settings and not others, I would look there, if your microwave is completely losing power when your starting it when you set it for 1 minute and hit start, then you probably have a bad TCO on your magnetron getting hot and losing connection. It could be that your Magnetron is getting too hot or just a bad connection on the TCO. If the magnet is cracked, I would replace the magnetron. I would recommend calling a professional if this is installed over your range, if you have ge service available I would go with them usually it takes two people to safely pull down a microwave. I would definately test it before reinstalling it again. 1800 GE CARES for gea service ask for the best deal if the magnetron needs replacement they are expensive.
SOURCE: G.E. Spacesaver Microwave - Keypad Won't Work
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
You may have a problem with the keypad or the control unit (circuit board / smart board).
We repair these on a regular basis. Details and *critical* safety, disassembly, and troubleshooting info is at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Please write back with more details if you need further help.
SOURCE: New GE Microwave JVM1750DM1BB with F4 error in Sensor cooking
GE
Microwave Fault Codes
Failure
Code
Condition
Check/Repair
F1
Open sensor, will
occur below 190F of cavity temperature within 15 minutes after
starting convection, combination or roast cook
Check oven temperature
sensor for continuity. Replace if zero or infinite ohms
F2
Shorted thermal
sensor, will occur if a shorted thermal sensor is detected
continuously over 5 seconds on convection, combination or
roast cooking
Note: It will take a minimum of 5 minutes of convection run
time before F1 or F2 code will be displayed if the thermal
sensor is shorted or open.
F3
Shorted key panel
(touch pad), will occur if a shorted key panel is detected
continuously over 60 seconds
Replace key panel
(touch pad)
F4
Open humidity
sensor, will occur if humidity sensor is detected as being
open continuously over 5 seconds
Replace humidity
sensor
F5
Shorted humidity
shorted continuously over 5 seconds
Replace humidity
sensor
F6
Shorted temperature
probe, will occur if temperature probe is detected as shorted
Replace temperature
probe
ProbEe
Open temperature
probe, will occur if temperature probe is detected open, or
not plugged into the receptacle
If probe is plugged
in and "ProbE" is on display check continuity of the probe
with an ohm meter. If zero or infinite ohms, replace it
SOURCE: microwave ge spacesaver touchpad does not work except for the
You have a failed
membrane keypad.
If you (or someone you
know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically
involved.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
There
should be a "mini-manual" (tech sheet) hidden inside the unit
behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting, testing, and locating
components.
If you would like to
have us
do this repair for you, we do that for $39.95 plus part costs nationwide.
But please note that for
some GE models, the membrane keypad is not
available as a separate part, so you would have to order the control
panel frame assembly which comes with a new keypad.
In this case, you simply
move your circuit board into the new frame. That is a simple do-it-yourself
job.
Either way, we can let
you know what your options and costs would be and send you other
helpful info.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your
full model number from the tag on the unit) for more
information & help.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Testimonial: "Thank you for your detailed response. Nice to know you are there for support."
SOURCE: GE Spacesaver Microwave touchpad
You almost certainly have a bad membrane keypad.
involved.
You can find
helpful exploded view diagrams and order parts by entering your full
model number here.
There
behind the
components.
have us
job.
helpful info.
At
information & help.
We're
We're happy
to help you. Once we have all your information and
offer a final solution, we'd appreciate your
thoughtful rating of our answer.
[email protected]
