SOURCE: need new adapter?
Clean the heatsink and fan assy and apply some thermal grease to the cooling pad on the CPU.. Its throttling back on batt. and not running full tilt. Vents are plugged/Obstructed/Clogged..
www.ikenfixit.com
SOURCE: where can I purchase a plug in outlet chord (power chord) for the osim medic 380 massage chair
If you are looking for the male end that plugs into the wall, you can use any 3 prong plug made for 120VAc. Just cut off the old one and connect wires to the new one. Black wire to brass terminal (if not brass or color coded, the smaller blade), white wire to silver terminal (no coding, larger blade) Green wire to green ground terminal. Secure in plug and you're goo to go. If you need to replace the plug on the unit itself if it has one or if its hard wired (usually is) you may need to disassemble that part to replace or reattach the cord.
