SOURCE: Propane fireplace insert won't light
Gas apliances have safety features built into them so you don't blow yourself up. The pilot heats a thermocoupler which tells the gas valve there is a flame, open the main gas to the burner. If you can see the flame area of the pilot look for a round post about 3/16 inch in diamiter. This should be directly in the flame, if not bend the bracket so it is in one side of the pilot flame. The thermocouple is attached to a mounting bracket. This will be held in place by a 1/4 inch hex screw. remove the screw and the capilary tube leading to the gas control valve. Before you do anything, close the main gas supply to the fireplace and disconnect the power to the fan. You may need to semi dismantle the fireplace to get the thermocouple. The gas valve end is a brass 1/4 pipe thread plug. Turn the outer nut and remove without twisting the tube. Reverse this order to install a new one. Besure not to twist the capilary tube, tighten brass nut 1/4 turn past hand tight. Your better heating supply house will have these in stock. Restarting the pilot will take a few tries because the gas was off. Your gas suplier would charge about $75 to fix this. if you don't have the proper tools and it dosen't look pretty stright forward don't do it. You could get dead.
SOURCE: I have a Martin ventless gas log fireplace. I
Sometimes when you turn a gas heater off for some time, if the source tank has been turned off, the line will bleed the propane and the line will contain mostly air. This is especially true if the supply line is long. In order to light the pilot, you will have to hold the pilot lighting button down for a while (a full minute or longer, depending on the size and length of the supply line) before pure propane arrives at the pilot light jet. You should keep a lighted lighter at the jet so that when the gas arrives, the lighter will light it. After the pilot lights, you will have to keep the button pressed long enough for the thermocouple to get hot enough to set the pilot to stay on. When it is hot enough, you should be able to release the pressed lighting button and the pilot should stay on. If it does, you should be able to light the heater. If the pilot jet never lights, gas is not getting to the regulator. If the pilot will not stay lit after a period of time waiting for it to heat the thermocouple, the thermocouple or the regulator may be bad and need replacement. :-)
SOURCE: gas fireplace won't light up even when pilot light is on
Check for how clean the bottom of the unit is. I know it seems small but when dealing with these amounts of electric current they are just that "small" and the dust can be shorting out the unit and not allowing the gas valve to release the gas. Its a safety thing, they dont want gas around an electrical short "go figure" lol
SOURCE: Need timer switch for millivolt gas fireplace
These guys are a division of Monessen, a gas fireplace manufacturer, and have a variety of millivolt switches, remotes and thermostats.
http://www.ambienttechnologies.com/
SOURCE: My Majestic DVR36RN gas-log fireplace
Majestic DVR36RN: Here's what you need to do: Verify gas line is open. (You said you already have done that). Next turn the switch to pilot (you said you did that too). Make sure wall switch is on also. Now press and hold the pilot switch and hit the ignitor. Once it lights you need to continue to hold the pilot switch for roughly 1 minute. Release the knob and the flame should stay lighted. Now, turn the knob to on. You should be all set now.
