Televison & Video Logo
Bruce Stockel Posted on Jan 19, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
On my flat screen tv I only have full screen coverage on certain channels. Why not all of them.
barrybam
Level 2:
Sergeant:
  • Expert 208 Answers
  • Posted on Jan 20, 2019
barrybam
Expert
Level 2:
Sergeant:
Answers
208
Questions
0
Helped
76751
Points
651
Not all channels are full HD TV
4 Related Answers
Jason Morris
  • 362 Answers
  • Posted on Feb 24, 2009
SOURCE: Picture size
Hi lm522,
You must change the aspect ratio.
  1. While viewing an image that dosen't fill the screen
  2. With the original remote
  3. Press  the Picture button on the remote
  4. This you allow you to cycle through options like Wide, Fill, Cinema
  5. Find the one that looks the best.
These instructions are not very specific, I will need the TV make and model for better instructions. Let me know how it goes and please rate this solution.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Anonymous
  • 2992 Answers
  • Posted on Feb 14, 2010
SOURCE: I have a Emerson (LC3203MC)
If you have this TV connected to a cable box or satellite receiver, the captions may be coming from there. Some of these devices support captioning on their own, separate from the TV. Check the device setup to be sure captions are turned off.
Anonymous
  • 476 Answers
  • Posted on May 19, 2010
SOURCE: there appears a black box on screens on certain channels
Hi, hit the cc button on your remote control untill the close caption display says off, this should eliminate the box from your screen
gopakumarg43
  • 76851 Answers
  • Posted on Feb 04, 2012
SOURCE: envision flat screen tv has 5 channels that don't play volume but show pic
Check the volute settigs to these channles. Check whether system set is compactable with input.
1helpful
Reset toshiba tv password
Turn on the TV and grab the remote. In most cases, you will need the original remote to unlock the TV if you aren't sure of the unlock code. If you don't have the original remote, you will need to purchase one.
Look at the screen. If you see a blank screen with a red key on the bottom of the screen, press 'Function' and 'Mute' at the same time. This should unlock the channel. This is an option for people who want the TV to stay locked but, want to be able to bypass the lock to watch a certain show or channel. All other channels will remain locked and the TV will fully lock when it is turned off.
Unlock all of the channels on the TV by entering the factory reset code. There are three main reset codes that TV manufacturers set. These are 0711, 6688 and 3308. Try each one until you find the one that works. This will reset the TV to original factory settings. When you do this, you will loose any information that you have stored in the TV, such as favorite channels, automatic timers and the clock. You will have to go through the full initial set up.
Call the technical support service number in your owner's manual if none of those codes work. A technician can help you troubleshoot the television because the problem may not be the locking control. When you call, make sure that you have the model number and serial number of the TV.
Take your television to a TV repair shop. In some cases, a professional who access to wiring diagrams for your television set may have to rewire certain components in order for the television to unlock. This is usually the case when the TV locks by itself while it is on.
1helpful
Can't get a full screen on some channels
I AM NOT AN EXPERT ON TV'S BUT ARE YOU AWARE SOME STATIONS PLAY MOVIES WITH THE SCREEN SHORTENED? ITS DUMB IF YOU ASK ME.
There appears a black box on screens on certain channels
I have a 32A14 Toshiba TV. At full screen, the
you have to take in affect on how old is the tv if you have had it a few years then the screen is going out and will only be a matter of time before it goes all the way out and you will be buying a new one if it not old and its one of the newer flat panels then its the signal that the tv is receiving if its hooked to a digital antena then you only get max of 720 from it on certain channels no matter if the channel or channels are showing hd with out a hd source your tv will not show better then that i have a 42 inch hd flat panel and use a antena and the best i get from my hd broadcast channels certain times will i get true hd like when the news is showing or when one of the series that was filmed in hd is on other then that i only get a 720 picture instead of a 1080 most commercals are not film in 1080 but in 720 max and i dont know why makes no since
Vizio 32lcd turns itself off on certain station
Do a full channel scan again. It should solve that problem.
1helpful
I get a thin line of distortion on my sony xbr 42in
Your format is wrong. Make sure that your tv is in full mode and your direct tv is in 1080i stretch mode. This should correct the problem. Also, WB is having problems. This is common on their channel. If it is happening on any other channel, try the above. Hope this helps. JOHN
Not getting full pic on certain channels
I've seen this problem before. Try to adjust the horizontal settings in the tv. you should be able to adjust the picture up just a bit and it will get rid of the lines. also if you are hooked up thru component or hdmi you should be able to press the # button on your time warner remote to fill the screen. Hope this helps.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
