I am trying to replace walking belt on Proform 585TL treadmill. Is it possible to remove the belt without taking the platform board?
I am trying to replace walking belt on Proform 585TL treadmill. I have removed rear & front rollers but it seems that belt can only be removed by by taking out the platform board. My concern is that the board is held thru two hefty looking springs, which may require very heavy pressure to reassemble. Please advise if this fear is reasonable or if an alternate way is possible. Thanks for your help
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both idler roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. (5 to 7 cm) off
the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
Walking Belt is Worn:
The only certain way to test for a worn walking belt is to take a DC amp draw (if you have a DC treadmill) or an AC draw (for AC). Trying to look at the belt or a feel test is highly unreliable. Better tests, if you lack a DC ammeter (they are expensive for a good one), are a coast test or an incline test.
The coast test is to get on the treadmill as the lowest incline setting and walk on the treadmill at 3 MPH. Pull the safety key and it should
take you 2-3 full steps to stop (this is a general rule…some like a few Tunturi models stop on a dime even with a healthy belt but for most models, this tests works well upon).
Fewer steps indicate high friction.
The incline test is to put the treadmill at max incline and walk on it at 3 MPH. If the treadmill operates normally at max incline but bogs down at minimum incline, replace the walking belt. Gravity takes over for the drive system eliminating much of the friction problem. On some heavily worn walking belts, this test will not eliminate the problem.
Go to your local hard ware store and purchase silicone spray. Apply Lubricant by lift one side of the running belt spray contents length wise starting at motor shroud to the back end repeat this process on the other side. If this unit bogs down again then you will have replace the running belt and possibly the deck
f the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD.Using the hex key, turn both idler roller bolts clockwise,1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. (5 to 7 cm) off
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn both rear roller adjustment bolts clockwise, 1/4 of a turn. When the walking belt
is correctly tightened, you should be able to lift the edges of the walking belt 3 to 4 inches off the walking platform. Be careful to keep the walking belt centered. Plug in the power cord, insert the key and run the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
Using the hex key, turn both rear roller bolts clockwise,
walking belt 2 to 3 inches above the walking platform.
the walking belt is properly tightened. Now if this does not solve this problem then check the drive belt and adjust accordingly, also reverse the process of the above mentioned
Unplug unit then, using the hex key, turn both idler roller bolts clockwise,
properly tightened.
Clean item up real good with damp rag-not dripping wet-dust/dirt will hurt walking platform/belt. Icon.com
Icon is the manufacture located in login Utah. Manuals can be downloaded through internet with model# of item, thats located on a silver tag in frt on frame,or under walking platform/mtr hood area. Proform did make one style that the model# was underneth...but thats been 10yrs ago
I would first watch the unit while walking and visably see if the drive belt is slipping or the walking belt is. If neither one seems slipping, it is possible that the torque control on the motor control board is not correct
