Question about Kohler Electrical Supplies
Error 5 on a Kohler steam generater. Where's the inlet screen on this unit? do I have to take it apart to get at it?
SOURCE:
  • 5692 Answers
SOURCE: I have a 1982 Evinrude 35 hp motor.
My smaller johnson had a pickup tube in the housing. With your alarm you only know when it is too hot. You do not know how close you are to setting the alarm at full throttle; it can be running hotter than it should then too. I would drop the lower unit, pull the sending unit and try to force water through the sending unit hole. This should backflush the head. Backflush the impeller housing too.
Posted on Jun 11, 2009
SOURCE: the kohler steam unit keeps shutting down prematurely
I've been struggling with this exact error for the past week and fixed it last night. The Error 5 message was misleading in my case and actually was caused by the steam outlet inside the shower and, even after replacing the entire unit and getting the same error, i fixed it in two seconds. Since this was one of the posting i encountered during my frantic searches, i thought i would come back and share my blog posting on this error and my fix:
http://fixitben.blogspot.com/2010/01/kohler-k-1658-240v-steam-generator-and.html
Posted on Jan 05, 2010
SOURCE: I have a Kohler K-7 steam generator/shower and
There is a float valve interior of the steam generator that supplies water to the generator unit. There are no parts available for that unit, and Kohler was useless re: repair. I have the same unit and mine is doing the same thing. I took it apart and there is a washer worth about a nickel that is inside the unit. I flipped the washer over in mine and it worked for about a week....then back to the same problem.
Posted on Jan 06, 2010
SOURCE: error code Prr
I had this problem, and checked the connections, emptied the resivour, and refilled it, and it had no effect.
To fix the problem, I ran the regular shower on hot for 10 minutes to warm up the shower chamber. Then, when I pressed the power button on the steam shower, it displayed "110" as normal.
The problem with "Prr" appears to be that the temp sensor is reporting a value out of range. Heating the shower chamber (and therefore sensor) provides a good value to the sensor, which then allows the shower to operate.
Try warming up your sensor by running the shower.
Posted on Mar 06, 2010
SOURCE: Mr. Steam Prr erro
my mr steam goes on by itself sometimes in the middle of the night...or in the day....why does this happen
Posted on Apr 14, 2011
I have a Kohler 12 RES home standby generator. Once in a while when the power goes out the generator will start and then immediately shut down with no fault codes. When I flip the control in the unit
Check the inlet fuel pressure, on exervise there is no load, when power is out it is loaded and demands more fuel. Also check for bugs blocking gas regulators vents etc
Nov 12, 2012 | Kohler Generator. 12 kW and 14 kW Home...
Kohler marine generator troubleshooting
I have a kohler marine generator that shuts down when it reaches operating temp of 200/210 degrees. It runs for about 5 minutes. Already replaced impella and have sea water pumping through, coolant level is good. Any suggestions? Thanks
May 02, 2012 | Electrical Supplies
I have Kohler 12Res generator,sometimes it runs fine and sometime it runs for 5 min and then shut down with error code UU (under voltage).I cant find authorized service center in Pakistan.Please help me to...
If it has a couple hundred hours or more, try cleaning the slips rings on the back of the rotor shaft. They should be very shiny and not black or polished looking.
Aug 09, 2011 | Kohler 12 kW Emergency Power System -...
Kohler Steam Shower. Getting ERROR MESSAGE 5. Need to know how to fix the problem.
check the steam outlet to make sure is properly tight this can cause a false ERR 5
ERR5 comes up when water flow to the unit is blocked or debris has gotten in the unit and clogged check filters,test the water flow
May 30, 2011 | Kohler Home
Error 5
-error 5 is caused by the back pressure of the steam head if water supply to the generator is sufficient and the steam output pipe to the steam head is plumbed according to the manual.
-Kohler recommends to modify the steam head to remove the wax motor, spring and snap ring in the housing. Call Kohler for instructions.
Jan 15, 2011 | Vibrant KOHLER Steam generator control kit...
I have an old thermasol steam unit 84 salvaged from a bath reno. there is a check valve on one pipe and a union fitting on the other. unfamiliar territory, how do i hook it up and what potential problems...
Check valve is the cold water inlet---valve keeps water from siphoning back out causing unit to boil dry. Probably is quite a bit of lime inside from "hard" water
Feb 06, 2010 | Thermasol Steam Bath Generators - Ambiance...
I have a Kohler K-7 steam generator/shower and after using it just fine, water now just pours out of the steam outlet - even if the unit is turned off at the control head. I have had to close the inlet...
Dec 05, 2009 | Kohler K-1698-G Brushed Chrome Tandem...
Mr. Steam Prr erro
Hi, kindly check the connection of your temperature probe down to the main board maybe its loose.
Oct 03, 2009 | Mr Steam Mr. Steam MS 81500E AutoFlush
Kohler 12res AC breaker flipping with no error listed
wat size c/breaker
6600 divide 240 = amp
rule of thumb
Aug 16, 2009 | Kohler 12 kW Emergency Power System -...
The kohler steam unit keeps shutting down prematurely
Since I don't have your model number for this, I am going to attempt an answer for you. Yes, there could be a filter but not always. Sometimes, the sensor on these units can become stuck closed and is sending a false error. Does the unit seem to be working? If it is, then it probably is a false signal. If not, the there could be debris that has gotten into the water lines. Either way, if the unit is new, then it will be under some sort of warranty. I would contact either Kohler or an authorized service rep.
Apr 05, 2009 | Home
Electrical Supplies Logo
96 people viewed this question
Top Kohler Electrical Supplies Experts
Sheldon Dedek
rjivaro
J. Bradshaw
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
