SOURCE: Fridge/Freezer combo - Freezer working fine but fridge is not
There is a duct between the freezer and refrigerator. Sometimes this duct blocks off with ice and won't allow airflow. Open your refrigerator door and check for air flow if there is none the duct needs to be defrosted. turn off freezer/ refrigerator and defrost.
SOURCE: Fridge wont get cold
DEFROST HEATERS IN THE FREEZER. IF THERE IS FROST ON THE BACK WALL INSIDE THE OF THE FREEZER SECTION. YOU THEN HAVE A DEFROST PROBLEM. REMOVE THAT PANEL AND DEFROST WITH HAIR DRYER. THIS FROST IS BLOCKING THE AIR FLOW TO THE REF. SIDE. AFTER THIS IT WILL WORK FOR 10-21 DAYS WITH OUT REPLACING A PART. THERE IS A BROWN AND ORANGE WIRE TO THE DEFROST SAFTY THERMOST. THE CONNECTOR ON THAT BROWN WIRE MAY HAVE FROZE APART. THE DEFROST SAFETY THERMOSTAT MAY HAVE FAILED. OR CONTROL BOARD MAY HAVE FAILED. BEHIND THE KICK PLATE IN A BAG ATTACHED TO THE BOTTOM OF YOUR REF. CABINET IS A TECH SHEET ON HOW TO FORCE A DEFROST TO CHECK THE SYSTEM.
SOURCE: The fridge is not working, not getting cold but
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
What is the model number?
