SOURCE: ice maker leaking water after replacing the solenoid valve two times
maybe the solenoid stays on too long during the fill cycle.. broken gear maybe or out of adjustment
SOURCE: ice maker
reach your hand into ice maker assy, is there ice in it and not ejecting??? there are tines that eject the ice, do these move around freely and easily(if so you need a new ice maker they should not turn by hand)
SOURCE: Kitchenaid ice maker water flow will not activate
You can post your the problem at my site by clicking the link below. Then click on free diagnosis, enter model number and the details and it may take a couple days to get the answer, but free. Let me know, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
SOURCE: Ice maker not working
I recently had trouble with both my water dispenser and my ice maker. I determined that my filter was clogged, so I replaced it. That fixed the water dispenser but the ice maker still wasn't working. I investigated further and found that the water inlet tube was frozen solid. Aparently, when the filter was clogged the water came in so slowly that it froze before it got to the icetray. I tried pouring hot water over the inlet tube to melt it and it mostly worked, but there was still some ice in the tube further back where I couldn't reach. Finally I defrosted the freezer so all the ice could melt and turned it back on and now it works great! Hope this might help.
SOURCE: GE refrigerator ice maker model can9 stopped
The schematic to my CAN9 is cast into the front cover.
