Televison & Video Logo
M
Maureen holt Posted on Jan 19, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My source button not working trying to get sky on
Pioneer plasma hd
Steven Fleming
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 61 Answers
  • Posted on Jan 20, 2019
Steven Fleming
Expert
Level 2:
New Friend:
Cheetah:
Answers
61
Questions
0
Helped
22565
Points
159
There should be buttons on the TV itself to try if your remote is not working. My guess is that SkyeTV comes into the TV through a HDMI cable, so look for HDMI input as source, not "Skye."
5 Related Answers
Anonymous
  • 196 Answers
  • Posted on Nov 11, 2008
SOURCE: do all 42PD3000 plasmas need hd upgrade?
according to the specs given on this site http://www.plasmas-direct.co.uk/plasma_tv/hitachi_plasma_tv_screen/hitachi_plasma_tv_42pd3000.html the tv is HD
puggy666
  • 48 Answers
  • Posted on Jul 07, 2009
SOURCE: onn 32 hd ready tv
you havent got another channle sitting on top of your hd channel have you . also is the hd cable pushed in all the way.
Anonymous
  • 325 Answers
  • Posted on Sep 02, 2009
SOURCE: sky magic eye not working on hd
I work for Sky as an Engineer.
on your Sky HD remote:
service,
4,
0 1 select
make sure the power is turned ON
now go to the room you can not change the sky channels over with.
you should notice on the magic eye itself should now have a Red led light on it now. you should now be able to change the channel over just remember to press the blue sky button on the remote at the top otherwise this will not operate the sky box.
If not unplug this magic eye and try this directly into RF out 2 to make sure that its not the magic eye that is at fault. If it is working correctly then the light will appear.
Hope this helps
Little dish fitter
Anonymous
  • Posted on Feb 20, 2010
SOURCE: Panasonic TX P50V10B Plasma TV
In order to get any of the Freesat channels, you need to connect a Satellite dish to your TV. If you have a Sky dish, you simply need to run an extra Cable from the LNB from the dish and connect to your socket on the back of your TV.
In order to get Freeview channels and Analogue channels, you need to connect a aerial to the back of the TV.
There is a menu option for the TV to start straight to the AV input (your Sky HD box). It is Menu > Setup > Other Settings > Power on Preference. Select 'AV' for your TV to start on Sky HD.
Also even if you have your TV to start on TV, when you turn on your Sky HD box, it should automatically switch to the Sky box.
Anonymous
  • Posted on Apr 05, 2010
SOURCE: copying to disc from sky HD with Pioneer DVR 530H
i want the mfd date of HDD S.R. No. 90Z94YRX
Cannot decrease vertical size enough using the menu controls. I cannot see the entire picture.
Incompatibility betwen source and tv.Try setting your source right.Set auto on Screen Ratio on either device.
Sky hd remote code needed please
Sky High Definition SkyHD uses a new design of Slim line remote control. The Default TV code pre-programmed into the RCU is now for Phillips and is (0)065. The SkyHD RCU is programmed in the usual manner using either the instructions in the Digital Installation Manual or via the Sky Customer Service option in the Interactive on-screen menu.
The SkyHD RCU can also be programmed to operate Sky+ boxes as well as SkyHD:
Press the TV button.
Press and hold SELECT and i together until the LED flashes twice.
Press the number button 1 and then press SELECT.
(Obviously you can't have a SkyHD and a Sky+ Digibox both in the same room).
Note: To re-programme the RCU for Sky HD box operation only, repeat the above process pressing the 2 button in step three.
Keep pressing HELP and waiting a few seconds until you find the correct command that activates the AV source you require then press SELECT.
The HELP button will now directly activate the chosen AV source instead of toggling through the alternative options to reach it.
There are 18 AV source commands to be tried before the RCU blinks 3 times to indicate it is out of options.
The Sky Guide buttons (SKY, tv guide, box office, services & interactive) can now be directed to use the same AV source as the newly programmed HELP button.
Press SELECT and GREEN until LED flashes twice.
Press HELP then SELECT and the LED will flash Twice.
The Sky Guide buttons will now instruct the TV to switch to the desired AV source and the RCU will be in Sky Mode.
Discussion here: http://www.digitalspy.co.uk/forums/showthread.php?t=944054
You can also use a Sky+ remote to control a SkyHD digibox.
See codes page for SkyHD
2helpful
14helpful
3answers
Technika sky code volume needed 42-502
0246 is the code 1st cover the top of the remote with your hand press TV you can now move your hand, now press and hold select and the red button togeather the remote light will flash twice enter the code 0246 then press select cover top again and press SKY button it should now control your tv
1helpful
Cannot program sky remote to operate volume control on pioneer pdp-4270xd pioneer plasma 42". have tried using code 0707 as this is the nearest I can find.
please follow the steps below:
TV
RED + SELECT (flashes twice)
TV
0166
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Set up surround sound with the following
YOU CAN ONLY GET 5.1 FROM THE OPTICAL OUTPUT ON THE SKY BOX NOT THE HDMI
SO CONNECT YOUR SKY BOX OPTICAL TO TV OPTICAL
PLZ LET ME KNOW IF THIS HELPS
JonnieC
Digital TV
It is HD ready, which means to get HD you will need to connect a HDMI cable to a HDMI source such as a SKY HD / VIRGIN HD SET TOP BOX or a HD DVD player to take advantage of HD.
Top Pioneer Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
