SOURCE: Lost manual--
See if your phones manual is here, if not probably similair instructions https://www.bellsouth.com/apps/nlss/index.jsp
SOURCE: msg button flashing
go to the phone where the light is flashing press intercom #409. you may have to do that more than once. Keep doing it until the light goes out.
If the phone system is a DK 8 orDk16 press intercom 409 this will cancel the message waiting light that could have been cativated by a different extension.
SOURCE: Remove The Casette Message
THESE CAMERAS ARE PEICES OF ****!!!!!!!!!!!!!!!!!!
I suggest that no body buys from cannon again!!
I am suppose to record my sister-in laws wedding and BOTH of my ELURA 100's are displaying the EJACT TAPE message!
"TEMP. FIX"
This takes pateince however for me it works....When you get the EJECT TAPE mesage....eject the battery with the power on (thus the power will go off by means of the battery not being in camera) then slap the battery back in....and KEEP doing this untill eventually the camera will NOT DISPLAY the message and actual work.
It may take up to 20 trys ....slap it in..slap it out...slap it in slap it out...BUt for me it works.
If it appears to work but as you hit the RECORD button it beeps and displays the EJECT tape message again...Go back and eject the battery again and repeat the STEPS...but dont worry , that means your getting closer to it working.. LOL
P.s- I hate CANON
SOURCE: constant flashing envelope on front screen
This is common on the Nokia N79. Your Sim card probably has text messages saved on it and the flashing icon is showing your sim sms memory is full. In the inbox go to the setting and view the sms on the sim, delete them and the message icon should stop flashing.
SOURCE: cant connect my HTC touch HD to PC thru activesync
1. Go to the settings.
2. From the options of Personal, System, & Connections, chose connections.
3. Tap on USB to PC icon.
4.
Here lies the demon. There is a small box with lengthy explanation line
(probably automatically ticked) which says "Enable faster data
synchronization" you just need to uncheck it and tap on ok.
Now the activesync will start working.
