SOURCE: i have a gas hot
check ot see if it has a safty eset on it. If it does then you can reset it and watch to see if it was just a intermittent problem or if it still locks out then you probly needd to ccall out a service company to check the uit out. Good Luck
SOURCE: banging from boiler when hot water turned on.
Install a knocker in the line and bleed the air out
SOURCE: hot water boiler will not ignite
Check all your limit switches on this unit. One of them is either tripped or bad.
SOURCE: my boiler is working for heating but not hot
check sector valves and valve to hot tank for water
SOURCE: Having problems with my hot water - my
Post question on Tank forum
http://www.thetankatwaterheaterrescue.com/forums/forum3/
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
