First place the thread spool on the spool holder and secure it with the spool cap. Bring the thread to the left and snap it into the thread guide. Wind the thread clockwise around the bobbin tension discs. (Bring the thread to the right side of the discs and and then around the discs. Bring the thread to the right and then insert the end of the thread into the hole in the bobbin. Make sure that the hole is facing up. Place the bobbin on the bobbin spindle and push the spindle to the right. Hold onto the thread that is above the bobbin and step on the foot pedal to start winding the bobbin. When the bobbin is full enough, stop pressing the foot pedal (or wait for the machine to stop winding the bobbin). Cut the thread and move the spindle to the left. Remove the bobbin from the spindle.
Many Singer sewing machine manuals are available from their support page: https://www.singer.com/support . The current link to the 4411 Heavy Duty sewing machine manual is https://www.singer.com/sites/default/files/product_manual/SINGER%204411%20Heavy%20Duty%20Sewing%20Machine.pdf . The directions and pictures for winding a bobbin are on page 12 (page 19 of the PDF).
I hope this helps.
SOURCE: Singer Sewing Machine model 9224. Bobbin thread
If you turn the handwheel, can you see a metal ring rotating around the outer edge of the bobbin case? If not rotating, broken gear or timing belt off.
If that ring is turning, remove the needle plate and bobbin case. As this ring now rotates, you will a finger on the ring that will pass behind the needle from right to left and it should catch the thread from the eye of the needle. If this finger, the "hook" passes above the eye, you have a timing problem.
Let me know.
SOURCE: thread balls up in the bobbin/singer sewing machine, also thread
The balance stitch control on this model is below the stitch patterns; to the far right.
If you need a manual you can download a free one at the Singer Company website.
SOURCE: how to thread the bobbin on a singer touch and sew model # 625
how to wind the bobbin of the singer touch and sew model 625
SOURCE: singer sewing machine won't pick up bobbin thread
Make sure that the area is clean and free of lint. Change the needle and rethread the machine.
SOURCE: How to thread a bobbin on singer 4411 sewing machine
If you've threaded the bobbin per instructions... then make sure your needle isn't damaged, bent, or dull. Also make sure the needle is seated fully and correctly oriented into the needle bar.
