Plugged in but no power showing anywhere. is there a circuit breaker in the dryer?
Sounds like you have the spin relay for the drum, stuck in a closed position. If you can locate where it is, you van give it a few taps to get it to disengage. You will then have to try to clean the contact on the relay that is sticking with a toothbrush and some spray contact cleaner that is safe for plastic. If this doesn't work, you will have to replace the relay or the contact. I hope this helps.
