Hello friend, thanks for your inquiry!
I understand that you have a Frigidaire refrigerator, FGHN2866PF1, and your deli drawer is freezing items. You may want to turn down the temperature within your deli drawer, when adjusting the temperature could take 24 hours for your refrigerator to stabilize. If that does not resolve your issue I would suggest removing the drawer and checking over to make sure there are no cracks where too much air may be coming in. If there is too much weight in the deli drawer that could cause the drawer to sag, which may release cold air into the deli drawer. I hope this information has been helpfu. -Matt
Hello friend, thanks for your post!
From what you are describing it sounds like you may have a bad gasket or seal. The best way to test this would be to place a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing it. If nothing is stopping the door from closing then replace the gasket. I hope this is helpful. -Matt
