SOURCE: fujitsu siemens stylistic M532 tablet not charging battery
I have just had same problem. Battery on M532 absolutely refused to charge from flat.Tablet worked when plugged in so I downloaded an app killer from android market and killed all but the essential apps then tried again and it seemed top work! Maybe background apps draining battery at faster rate than could be charged?
SOURCE: Coby Kryos Android Tablet
Leave the tablet connected to the charger for 5-10 minutes even if doesn\'t work. Then take out the battery and try with master charger and (switch on the tablet) after that, check whether the previous charger is working again or not again. If it doesn\'t show charging sign, then you have to take it to service center to change the charger connector.
SOURCE: Both Charger Ports Wont Take Charges
i can suggest you get a Duracell wireless charger which you just place your tablet on and it charges?
SOURCE: My tablet dosent wwnt to charge anymore.the chatger falls out where u connect it.
A problem like this is usually due to a loose DC IN socket on your tablet. In such case, the socket may have to be replaced or resoldered. Your charger is most likely still ok. You can confirm this by using it to charge another tablet.
SOURCE: prestigious tablet does not charge, it keeps dropping percentages
try turning it off power down if not plug it in to computers usb
